Ground locations?
Old Feb 25, 2015 | 10:05 PM
Factor's Avatar
Factor
Default Ground locations?
Hi all!
Looking for a small ground for the HEI...do inspection plate bolts work on the plate??
THANKS!
R
Old Feb 26, 2015 | 02:50 PM
MelWff's Avatar
MelWff
could you clarify your question, are you talking about the module ground as in this article?
http://www.onedirt.com/news/pumping-...nition-module/
Old Feb 26, 2015 | 03:24 PM
mikem350's Avatar
mikem350
HEI does not use a separate gnd. It grounds thru the housing to the block.
If swapping from a points type ign make sure its getting full 12v, not the ballast wire.
Old Feb 27, 2015 | 08:00 AM
Factor's Avatar
Factor
it is for the black grounding wire of the distributor...
is the inspection plate bolts a decent ground?
can you ground on aluminum heads?
thanks!
R
Old Feb 27, 2015 | 12:18 PM
MelWff's Avatar
MelWff
something doesnt make sense, why would you have an external grounding wire on a HEI distributor ? Aluminum heads will conduct electricity and can act as a ground providing the block has a ground to the frame somewhere.
Old Feb 28, 2015 | 10:35 AM
Factor's Avatar
Factor
this is the ground...
To Ground locations?
