Brake Booster
Old Feb 28, 2015 | 08:27 PM
kanvasman's Avatar
kanvasman
Default Brake Booster
I am in the process of replacing my master cylinder and noticed that with the master cylinder out of the car, I can easily depress the brake pedal, meaning only slight resistance from the power booster ( no vacuum going to it either). I have only driven the car a short time since i got it, and knew that some of the calipers were leaking, so I knew I had air in the system and a low pedal. So on the bench, should there be a soft or hard pedal with no vacuum to the booster and no mast cylinder installed? Thanks.
Old Feb 28, 2015 | 09:44 PM
'75's Avatar
'75
The master cylinder creates the resistance at the pedal, so with it removed the pedal will move very easily.
Old Mar 1, 2015 | 12:54 PM
kanvasman's Avatar
kanvasman
That's what I was thinking, but needed a second opinion. When I work too long, I forget the simple things and try to turn everything into a PROJECT. Thanks.
To Brake Booster
