summit cam
Old Aug 9, 2002 | 10:47 PM
dogboy's Avatar
dogboy
Default summit cam
Anyone with an l48 use the summit k 1103 camshaft? Seems like a good deal with lifters for that price.
Old Aug 9, 2002 | 11:43 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: summit cam (dogboy)
yes ive used it and i have a brand new one sitting on the shelf right now...ran it in a 350 8.5 compression edlebrock performer manifold holley 600 carb 2 1/2 duals with a 3.08 rear,had plenty of low end torque pulled to about 5200.auto trans with stock convertor but the cam was advanced 4 degrees when i put it in to help with low end.for the price its not bad.
[Modified by pats406nitrovette, 10:44 PM 8/9/2002]
Old Aug 9, 2002 | 11:50 PM
dogboy's Avatar
dogboy
Default Re: summit cam (pats406nitrovette)
Did you change out the valve springs or leave in the stock ones?
Old Aug 9, 2002 | 11:58 PM
rpounds's Avatar
rpounds
I am currently running a Summit 1101. Of course, I change cams more often that some people change their underwear . . . :-)
I am VERY pleased with the low end. Pulls strong through normal street RPMs . . . a good deal for the money . . .
Old Aug 10, 2002 | 12:01 AM
PatsLs1vette
i had a set of stock 882 castings with stock replacement valvesprings in it good for 500 lift.that cam i believe had around 442 to 465 lift right?you should be fine if your springs are in good shape.Im always trying different cams and brands all the time and the summit cams for the money were pretty decent.
[Modified by pats406nitrovette, 11:02 PM 8/9/2002]
Old Aug 10, 2002 | 12:08 AM
Rocket Ron's Avatar
Rocket Ron
I would think twice about a generic part like that. I bought a summit electric fuel pump and after returning it for the second time for not working, I bought the holly instead.
Is the came made in america?
Is it worth saving 20 or 30 bucks.
Old Aug 10, 2002 | 12:46 AM
dogboy's Avatar
dogboy
Default Re: summit cam (Rocket Ron)
Made in the USA
To summit cam
