After test several electricals on the 81 a friend mentioned that resistors in the computer can be blown by an analog meter...oops. Everything seems OK, but I had never heard that...time to go tool shopping...
I do not believe this is true, resisters do just that resist electricity the amount of power coming from a volt/ohm meter is so small it makes it almost imposable. I am an aircraft technician and I test computers far more complex and sensitive than automotive computers and have not burned one up yet. If any thing I find that a digital meter will induce stray voltage in to a circuit when testing an airframe for micro volts
NO, it would have to be a highly unusual situation, so unusual that it ain't a gonna happen....
now at one time in a chip's life it can be blown by such things, but when it's mounted on a card, and the card is complete, the input gates are held neutral by much lower resistances than they would have open circuit....so handling is not an issue....
NOW having said that....STATIC discharge will allways be an issue, that's why most automotive computers are in an aluminum box....the wiring from the loads/sending units is too low an impedance to be a threat....
I also suggest that most aircraft are in a high EMI environmnet, and as such it's the DVM LEADS putting signals into wiring acting as an antenna....have to use something shielded, like a scope probe, should cut down alot on that...
Buy a Fluke meter. They cost more but they are the best meter out there and they can be fixed or recalibated with no problems. If you dont need to read amps Id get the Fluke 12 meter.
