Mixture Screw Operation
Old Mar 4, 2015 | 09:51 PM
Cavu2u's Avatar
Cavu2u
Default Mixture Screw Operation
To make the idle mixture on the Quadrajet leaner, the 2 Mixture Screws screw IN, correct?
Thanks.
Steve
Old Mar 4, 2015 | 09:55 PM
Peterbuilt's Avatar
Peterbuilt
Yes:
in =lean
out= rich
Old Mar 4, 2015 | 10:45 PM
Cavu2u's Avatar
Cavu2u
Originally Posted by Peterbuilt
Yes:
in =lean
out= rich
Old Mar 4, 2015 | 11:29 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
FYI.."........One of my mixture screws didn't affect the idle.....I took the top off the carb and used air pressure and a wire to force the trah out....it adjusted correctly after cleaning.
Old Mar 5, 2015 | 05:02 AM
Cavu2u's Avatar
Cavu2u
How did you know that is my problem?
Steve
Old Mar 5, 2015 | 10:43 AM
doorgunner's Avatar
doorgunner
Steve
The passenger's side screw worked correctly....so I took the top off the carb/removed THAT mixture screw and used a rubbertipped air nozzle to blow 50psi air into the screw opening/located the air-exits in the carb by feeling each tiny hole in the internal area of the carb.
Then I removed the mixture screw from the "bad" idle circuit/blew air in with no results---no air exited through the identical holes on that side of the carb---I found a wire the correct diameter that would fit into the clogged exit holes and slowly fed the wire in---tiny pieces of sand/trash came out of the idle mixture screw-hole....I used more air pressure and the wire again until there was good airflow in both directions.
Reassembled and adjusted carb/worked great/idled great.
Old Mar 6, 2015 | 04:33 PM
7T1vette's Avatar
7T1vette
Make sure the fuel filter in the carb (or in the fuel line) is still good and doing its job. No way for that kind of stuff to get in there, unless the fuel filter is clogged/damaged or not there.
Good catch!!
Old Mar 6, 2015 | 04:45 PM
doorgunner's Avatar
doorgunner
I forgot!
VERY TRUE about filters!
An inline filter right before the fuel pump will spare the pump AND the carb! One at or in the carb won't hurt either
Old Mar 6, 2015 | 06:44 PM
Cavu2u's Avatar
Cavu2u
I forgot!
So, would an inline filter fit best up front (between hard line and pump) or in the back (out near the tank)?
Any examples out there?
Steve
Old Mar 6, 2015 | 06:50 PM
Peterbuilt's Avatar
Peterbuilt
On a Q-jet there should be a filter where the hard line from the pump connects to the carburetor.
There is a long or a short filter so get the correct one.
Old Mar 6, 2015 | 08:13 PM
Cavu2u's Avatar
Cavu2u
Yes, I replaced the paper one that went in the carb, where the supply line screws into.
Steve
Old Mar 7, 2015 | 08:41 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Steve
FWIW, a number of years ago, while working on one of my "winter cars" (which wasn't a Corvette, of course) I found that the rubber "flex line" between the hard line on the frame, and the fuel pump, was in bad shape. So, I figured, since I was replacing the line anyway, why not stick a filter in there, along with a couple of new, short pieces of rubber line. As "doorgunner" said, might as well protect the fuel pump too....
Old Mar 8, 2015 | 03:59 PM
Peterbuilt's Avatar
Peterbuilt
On a C-3 the rubber line between the tank hard line and the pump has to be a 'special' molded rubber.
A regular rubber line can kink and block the fuel flow.
To Mixture Screw Operation
