tach on 15 when car off
Old Mar 6, 2015 | 01:05 PM
mwm3006's Avatar
mwm3006
Default tach on 15 when car off
Tach is off. On 10 to 15 when car is off. Can you just pull the needle off and adjust like if it was a clock or will that break if? What to do??
Old Mar 6, 2015 | 01:41 PM
65GGvert's Avatar
65GGvert
What year car is it? Electronic or mechanical? When you turn the key on, does it drop to zero?
Old Mar 6, 2015 | 01:52 PM
mwm3006's Avatar
mwm3006
It's a 79. Surely mechanical. No it doesn't drop to zero.
Old Mar 6, 2015 | 02:04 PM
JimLentz's Avatar
JimLentz
A 79 is electronic and the most likely cause is the circuit board. Does the reading seem right other than being off by 1000 to 1500 RPM when the car is running?
Old Mar 6, 2015 | 02:09 PM
mwm3006's Avatar
mwm3006
Yes it works right. Just way higher than it should be. Runs up into yellow and red when it should not. Does work right though. Just starts off at 10 to 15.
Old Mar 6, 2015 | 02:17 PM
JimLentz's Avatar
JimLentz
You can remove the needle and place it back on where it should be. I am not sure on your '79, but my '77 was a real pain to get to.
Old Mar 6, 2015 | 02:46 PM
hwcoop's Avatar
hwcoop
i seem to remember them doing this even when they were new...kind of like the fuel gauge, just kind of floats until the key is turned on
Old Mar 6, 2015 | 03:29 PM
65GGvert's Avatar
65GGvert
Yeah, it's electronic. They usually drop to zero when you turn the key on without starting the engine. I'm not sure if moving the needle is your answer or not, not knowing how the reading is at higher rpm's.
Old Mar 6, 2015 | 04:02 PM
mwm3006's Avatar
mwm3006
OK. I did just turn the key on without starting and it does go to zero. Just seems to be running higher than I would expect. Idles at like 15 but car is idling about normal. Not fast idle at all. Engine has been beefed up a bit from the original 190 HP (thank god) Probably no more than 250 tops I would guess. If I recall 60 mph is running at about 3500 to 3800 I believe.
Maybe I'm just used to my newer vehicles with 6 and 8 speed trans.
Old Mar 6, 2015 | 04:24 PM
65GGvert's Avatar
65GGvert
Sounds like your tach is fine. Hook up an external rpm gauge, like a dwell meter to double check it. It's normal to read some value when switched off as long as it drops to zero when powered on. Not knowing what transmission and what rear gear ratio you have, it's impossible to gauge what your rpm should be at 60. I have a 3:08 and it runs 2600 rpms at 70mph, so you sound like you're in the range depending on the rear axle you have.
Old Mar 6, 2015 | 07:49 PM
mwm3006's Avatar
mwm3006
Took the car out again. 60 mph tach says 4300. 70mph is in the yellow at 4800. Don't feel like it's wound up near that much. Could have a lower rear end installed. Oh well. no big deal I guess.
Old Mar 6, 2015 | 08:38 PM
BKarol's Avatar
BKarol
Here is a large PDF file from GM Heritage about the 79 year that you can look through at your leisure:
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
Appears in 79 if you ordered a L48 4spd the std rear was a 3:36 & an auto would be 3:55. I have a 3:70 and at 60mph I am at 3200 and 70mph @3400. I can't imagine someone putting in a rear gear that you are at 4800.
Check on the Willcox site for their help on tach problems or do a "search this forum" at the top of the page & enter tach problem. You will get some hits. Good luck.
Old Mar 6, 2015 | 09:46 PM
mwm3006's Avatar
mwm3006
thanks for the info but I know this tach has to be screwed up. I am not wound up that much at 70. Car is fairly normal and smooth at 70. I used to have a 59 vette that was wound as heck at 70. The rear end was like a 456 or something. This rear end seems pretty normal. Just trying to ignore tach. Thanks again.
Old Mar 6, 2015 | 10:13 PM
BLUE1972's Avatar
BLUE1972
as a long shot, unplug the tech from the distributor and clean the contacts, also unplug the power feed to the distributor and clean the contacts. If the tech changes when you turn on the lights or turn signals check the grounds.
Old Mar 6, 2015 | 10:46 PM
65GGvert's Avatar
65GGvert
That's too high. You'd know if you were winding 4800 at 70.
Old Mar 7, 2015 | 09:12 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The 1978-1982 tachometer is supposed to hold the last signal sent to the board when the tach is shut off. However, in this case it sounds to me as if someone has maybe replaced the board and not done a zero set on the needle.
This info will get you back on track and show you how to do a zero set. If a new zero set works, then your set. If it fails post again.
Willcox
Tach Board installation 1978-1982
Corvette Tachometer Board Installation Instructions 1978-1982
Corvette Tachometer Testing, Removal, Board Installation, Video Link 1978-1982
To tach on 15 when car off
