LSA into a C3
Old Mar 10, 2015 | 07:20 PM
aussiemartin69's Avatar
aussiemartin69
Cruising
Default LSA into a C3
Hi all,
I would like to hear from anyone who has fitted a LSA crate engine into a C3. My queries are will it fit in with the standard accessory drive kit, or do they do a kit specifically for the C3 as the engines are advertised as being for pre 1976 vehicles. Also, as we are right hand drive here in Australia, I was wondering if they do optional kits with the A/C compressor on the left and the power steering pump on the right. I have tried Summit Racing, where I will probably get the LSA controller, accessory drive and A/C add on kits, but they were unable to give me any advice.
I would appreciate any help,
aussiemartin69
Old Mar 10, 2015 | 07:59 PM
74modified's Avatar
74modified
I don't know of anyone with an LSA, but there are plenty of regular LS swaps. You will probably need extra hood clearance with the supercharger.
The low mount A/C will not work on the C3, so your right hand drive should not be a problem. You could use a high mount right hand A/C. I am not sure how low that oil pan hangs, I think it is a rear sump. Good Luck
Old Mar 10, 2015 | 08:28 PM
aussiemartin69
Cruising
Bonnet clearance shouldn't be an issue. The top of the supercharger sits about an inch lower than the air cleaner version. Also I've grafted an LT-1 hood into a 73 and later hood and added an extra inch. We'll be using one of these on this car. I have also developed a RHD rack and pinion steering conversion for the C3's, so you're right, I'll look into the sump issue. Thanks.
Old Mar 11, 2015 | 07:44 AM
Garys 68's Avatar
Garys 68
Swapping the PS is a tough one.
With the AC compressor mounted on an LSA, check out this thread:
http://ls1tech.com/forums/conversion...w-mount-c.html
Old Mar 11, 2015 | 05:12 PM
aussiemartin69
Cruising
Interesting reading. Thanks.
To LSA into a C3
