Key buzzer ?!?
Old Mar 7, 2015 | 06:01 PM
Jhiltonn's Avatar
Jhiltonn
Default Key buzzer ?!?
Could someone please explain the differences between the key warning buzzer that is between my speedo and tach on my 72, and the key warning buzzer that resides in my tilt/tele steering column?
Neither works as I've never heard buzzing ever, but today I removed my dash pad and figured I would check out that module between the speedo and tach. Darn, I was also hoping to find a build sheet in between there, oh well.
Just wondering how I should proceed to get everything fixed?, and how both are supposed to function? Are they mutually exclusive or do they work in tandem?
Thanks! Joe
Old Mar 7, 2015 | 06:07 PM
DUB's Avatar
DUB
Are you referring to this????
http://www.ecklerscorvette.com/corve...1972-1976.html
The part in your column is the switch that lets the buzzer know when to work if the key is still in the ignition.
DUB
Old Mar 7, 2015 | 06:41 PM
Jhiltonn's Avatar
Jhiltonn
Yes, that's the piece. Is there any way to test it once it's been removed from the car? I have it out, and took off the black cover.
But I really would like to know how this module works, and if it works in conjunction with that other key warning module that's buried somewhere deep in my steering column?
Old Mar 8, 2015 | 05:37 PM
DUB's Avatar
DUB
Do you have a wiring diagram????? IF not..you might want to get one.
There is NO module buried deep in the column...as I wrote in the past post...all there is.... is a switch that when the key is IN the ignition switch...the switch closes....and it sends a signal to the buzzer....and this also uses the door jamb switches.
DUB
Old Mar 9, 2015 | 05:25 PM
Jhiltonn's Avatar
Jhiltonn
I tested the 6262663 module using a 12v power source, but got nothing, then I checked the plug that it goes into with my multimeter and got no power at all going to the plug; I checked it with the key in the ignition and turned on, but no juice is going to that plug where the 6262663 module is. What does that mean?
Thanks, JH
Old Mar 9, 2015 | 05:33 PM
DUB's Avatar
DUB
READ the first sentence in post#4 and reply.
Old Mar 10, 2015 | 12:40 AM
Jhiltonn's Avatar
Jhiltonn
Yes I do have a wiring diagram
Old Mar 10, 2015 | 07:19 PM
DUB's Avatar
DUB
GREAT...I will bring my wiring diagram home with me tomorrow and help you....if you still need help.
Are you testing the original key warning buzzer module....or a new one???
NOT meaning to be a smart @ss...do you know how to read and understand a wiring diagram??? Please do not take offense in that question...but it matters if I know if you know how to or not...because if your REALLY know how to read a wiring diagram and understand circuitry...then you do not need my help. If you don't...and you live in the United States. You can PM me and I can give you my shop phone number so we can talk on the phone....when you are at your car...and I can aid you in understanding the circuitry and your can do tests with me on the phone....instead of us typing for hours on this issue.
It is up to you. If we have to type back and forth...then I will help you if you need it.
DUB
Old Mar 11, 2015 | 05:38 PM
Jhiltonn's Avatar
Jhiltonn
DUB
I'm trying to test the original key buzzer that was in the car. I have a Dr Rebuild wiring diagram and I'm a novice at reading it. I understand just the basics, so I could use your help. I'll PM you so we can talk on the phone. Thanks! I really appreciate the help!! Joe
To Key buzzer ?!?
