engine vacuum leak
Old Mar 10, 2015 | 07:36 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Default engine vacuum leak
Been chasing a rough running engine. At cruise speed (55-75) the engine will surge. Have gotten it better by upping the jets. (Holley) Still have a misfire thru the exhaust and will spit and sputter if I drop into first gear and accelerate. (Automatic)
Replaced the plugs, checked the plug wires, rebuilt carb, even checked all the wires inside the distributor.
Tonight I sprayed some carb cleaner and starting fluid around the hoses and intake, no change until I got to the runners for 1&3, the idle dropped when I sprayed that area.
Good indication of a bad intake gasket?
TIA
Old Mar 11, 2015 | 11:31 AM
REELAV8R's Avatar
REELAV8R
Sounds like you're on the right track. If it's just sucking vacuum and not oil or water you could just clean it up and apply some RTV sealer to that area. Something like permatex ultra black.
Old Mar 11, 2015 | 07:48 PM
DUB's Avatar
DUB
Personally I would not use 'starting fluid'...it is highly flammable and a serious fire risk. If you do...just be real careful....that ether is wicked.
Also..when I do what you are doing.... usually the idle increases when I find a leak....and the idle not drop.
DUB
Old Mar 11, 2015 | 08:08 PM
procketus's Avatar
procketus
DUB
Well nothing on fire or blew up. I was careful.
As far as the idle, I always thought it should rise, not drop. Going to try some more tomorrow.
Some trouble I'm having is the idle is rough anyway with the cam that's in it. Kind of hard to tell when and if it smoothens out.
REALLY want to get rid of this surging and misfire.
Old Mar 11, 2015 | 08:11 PM
procketus's Avatar
procketus
Thought about trying some RTV. Wouldn't it get sucked in thru the leak?
Probably be just a temporary fix anyway.
Old Mar 11, 2015 | 10:10 PM
TPI BOY's Avatar
TPI BOY
The idle will increase because your
throwing more fuel in the fire
Old Mar 12, 2015 | 06:25 PM
DUB's Avatar
DUB
OK...now the picture gets more in focus due to more information. Always seems to happen that way.
Now knowing that you have some type of cam in it that more than likely more performance minded than factory. That changes 'things' depending on how radical it is..
Not knowing what your engine vacuum is so the power valve in the Holley is/are correct...well that is another.
Re-jetting it but also still having backfiring in eh exhaust...I wonder if you have a fuel issue that may not have been addressed when the carb was rebuilt.
Not knowing what you timing is set at and how the advance is set up and what is reads....that is another.....and that is ASSUMING that the notch on the harmonic balancer has not spun and has been verified... UNLESS the harmonic balancer was replaced....so if you are using a timing light...it is worth while....because setting timing when a the balancer outer ring has spun....is pointless.
Also...removing all vacuum sources for the headlights and AC system and capping off that port and see if that helps...because I have worked on many Corvettes where the headlight actuator relays were shot and such a serious vacuum leak there...it effected how the car ran.
DUB
Old Mar 12, 2015 | 08:23 PM
procketus's Avatar
procketus
DUH..I never thought about the headlights..will check that area tomorrow.
Vacuum reading is just about 20 inches on my VERY old gauge. I replaced the PV with a 6.5
Both idle screws out 2 3/4 turns for highest vacuum.
Even put my old plugs back in thinking I may have gotten a bad new one.(AC Delco R45ts)
I'm now fairly certain it's NOT a vacuum leak in the engine area. I did some "tests" today and idle did not change. May have been my wishful thinking/imagination using that starting fluid.
I'm also having visions of a new cam needing to be installed.
And/or a valve job.
Just went back and reread my original post, when I mentioned it misfires in exhaust, I left out(thought I added this) that it backfires thru the carb also. Sounds like a shotgun going off.
Old Mar 13, 2015 | 06:08 PM
DUB's Avatar
DUB
And/or a valve job.
It seems to be the consensus that when you get a GOOD backfire through a Holley...the power valve(s) just got ruined....and may need to be checked.
I do not know if it is your problem.....but if you are getting spitting back up through the carb...that is a good indicator that you have an exhaust lobe worn off your cam or something going on in an exhaust valve somewhere. Usually requires pulling off the valve cover and killing the ignition and spin the engine over and WATCH your rocker arms and see if there is one not acting/moving the same.
DUB
Old Mar 13, 2015 | 08:25 PM
procketus's Avatar
procketus
DUB
Yep, gonna do that tomorrow. Taking a brain break from it tonite. I MIGHT try to figure a way to mount a dial indicator I have here to get a good read.
BTW..got any good heads laying around at the shop? Not sure if Gary has any but I also know someone with a set of Vortecs.
Old Mar 14, 2015 | 05:19 PM
DUB's Avatar
DUB
Yes I do have cylinder heads but they are my 'keepers'.
I would be careful in putting in some serious heads...and not 'possibly' addressing any compression issues or poor ring drag on the engine. I am in the belief that if a wicked set of heads are put on an engine that has a cast crankshaft and weak rods and cast pistons...it is a recipe for disaster. If your bottom end is not stout...putting on some small cc heads will raise the compression and cause for something to 'possibly give way'. I am NOT writing that you would have a problem.....but it just makes sense to me to get all the parts to the strength they need to be if you are building a strong engine.
DUB
To engine vacuum leak
