1981 Unknown Engine Internals, Compression Test?
Old Mar 12, 2015 | 11:28 PM
zakbradshaw's Avatar
zakbradshaw
Default 1981 Unknown Engine Internals, Compression Test?
I bought a 1981 C3 a few weeks ago. The seller said the engine had been rebuilt 10k miles earlier by the owner before him but had no idea what had been done to it. It runs great and feels like it has tons of power, but all I know is it has a "bigger" cam. How can I check the actual compression ratio without tearing into it to find out what internals were used? I would like to do some performance stuff to it but want to know where I'm at with what I have so I know what upgrades to do. If compression is still low like it was from factory I will look at doing the 58cc L-98 heads first then do intake/carb/etc. Just out of curiosity, if I go with the aluminum L-98 58cc heads, will my accessory stuff bolt straight on, and should it work with my headers/side pipes currently on my car? Thanks guys!
Old Mar 13, 2015 | 11:37 AM
MelWff's Avatar
MelWff
You cannt tell the actual compression ratio without tearing into it. A high compression engine with a radical cam will give low numbers during a compression test just like a low compression engine. You can try removing the valve cover and use a dial indicator to determine some characteristics of the cam. Checking the head casting numbers will tell you what heads are on the car low or high compression but wont tell you if the pistons were changed.
Old Mar 13, 2015 | 11:55 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie question: Would one of those little Harbor Freight Inspection Cameras fit in the sparkplug hole so that he could see the piston top....also go in through the oil plug drain hole to see if it has two-bolt or 4-bolt main caps......also listen to the whine from the timing cover would tell if it's chain or gear driven?
Old Mar 17, 2015 | 09:32 PM
zakbradshaw
I like this suggestion. Anyone?
To 1981 Unknown Engine Internals, Compression Test?
