Help! Is This Rag Joint Correct???
Old Mar 13, 2015 | 10:24 AM
jsera's Avatar
jsera
Default Help! Is This Rag Joint Correct???
Hi guys, I took my vette to a shop in town and had my rag joint replaced because from what it seems, after doing the borg box install the steering shaft might've been left too far back thus tearing the rag joint as seen in the first two pics. After the rag joint was replaced, i noticed that the two studs that make contact with the steering shaft part dont quite reach in order to make proper engagement, leaving all the stress of turns up to the rubber part alone.
The 3-5 pic show the new rag joint installed. Does this look correct? It seems a bit sketchy to me but I figured I'd ask here before bothering back at the shop that did the work.
Old Mar 13, 2015 | 10:56 AM
persuader's Avatar
persuader
I am seeing a most unsafe condition.
Your situation is more than the wrong rag joint. What I men is the installation is the big problem here. Looks like all they did is replace the rubber isolator and thats it. The column has to be extended out about a 1/2 inch, and there is hardware missing from the attachment points, Like the metal bridge that crosses from one side to another and acts like a washer between the rubber and the nut. The new rubber isolator is already showing signs of stress because of being tightened down using the incorrect hardware. IMHO.
I am sure some others will chime in who are better at explaining things on a keyboard than I.
BTW. It is always best to install an OEM new rag joint. I know they are discontinued but they are out there although expensive. The repos are ok if you know what you are looking for. The rebuild kits are for the most part junk. Again, IMHO
Old Mar 14, 2015 | 09:19 AM
Ranger24's Avatar
Ranger24
Also, Borgeson usually provides a new rag joint with their conversion kit. I just sent two of them back...long story...but they appear to be solid units.
Old Mar 14, 2015 | 09:45 AM
Alan 71's Avatar
Alan 71
Hi J,
This picture illustrates the normal position of the 2 parts of the joint.
Compare it to your picture.
As P indicated the folks who installed your rag joint weren't looking out for you.
Regards,
Alan
Look at your #3&4 pics.
Old Mar 14, 2015 | 10:31 AM
65GGvert's Avatar
65GGvert
The Borgeson box takes a different rag joint connector than OEM box. The steering column side is the same. It looks to me like you compressed your steering column about an inch too much. It should be able to be extended toward the box to make the joint fit tighter.
Old Mar 14, 2015 | 04:49 PM
7T1vette's Avatar
7T1vette
Those 'reaction' pins need to be fully engaged in the slots on the mating piece. Otherwise, if the rubber fails, the steering wheel could just spin around with no motion transferred to the steering box.
The bottom end of your steering column might have collapsed a bit, due to installation forces. The design of the steering column is such that it will collapse under frontal collision, rather than transferring forces to YOU.
Old Mar 16, 2015 | 11:44 AM
jsera's Avatar
jsera
It seems to be the case that the column is collapsing on its own. i took it back, we pulled the shaft back down and a day later it went back up. The car is missing that washer that goes across the bolts though if that makes any difference?
Old Mar 17, 2015 | 12:00 PM
mysixtynine's Avatar
mysixtynine
I see two things.
1. You dont have the lower clamp on the bottom of the steering shaft? See my picture below. I have a borg in mine and I still have the lower clamp on mine between the lower bearing and the rag joint so the shaft cannot creep backup (even if it could move). My column shaft was 4 1/4" from the bottom of the steering column bearing to the tip of the shaft prior to installing the borg... then compressed it was 1 7/8" to get the borg in. Yours seems too far compressed into the column.
2. Maybe its the picture... but your headers are freaking close to the rag joint. Is it possible it was melted by the heat??
Old Mar 17, 2015 | 01:24 PM
jsera's Avatar
jsera
Originally Posted by mysixtynine
I see two things.
Got any more pics of that clamp? I know I am missing this for sure if 78s were supposed to have it.
Also would this possibly be the lower bearing?
Lastly your eyes do not deceive you, my headers come within a half inch of the rag joint... but the shaft is collapsing which seems to be the main issue
Old Mar 17, 2015 | 02:03 PM
mysixtynine
This thread is giving me fits... I cant get to the bottom of the page to reply to your question so i am putting in a new post.
I am not sure about the 78 column but my 69 has the clamp.
Here is another pic of my column before I rebuilt it.
Old Mar 17, 2015 | 09:29 PM
65GGvert's Avatar
65GGvert
The purpose of the collapsing shaft is to help stop the steering wheel from impaling you in an accident. If that collar is bolted down, that would override the collapse. For what it's worth, my 72 doesn't have and has never had that clamp, and the column doesn't collapse when driving as yours is.
Old Mar 17, 2015 | 09:52 PM
69vette19467's Avatar
69vette19467
I think the clamp was only used in 68 and E69.
To Help! Is This Rag Joint Correct???
