Vacuum system on 1969???
Old Mar 16, 2015 | 02:24 PM
Factor's Avatar
Factor
Default Vacuum system on 1969???
OK! So I swapped engines and now am having issues with the vacumm lines...from the interior ( I believe)
the AIM does not have a very good layout...
I pulled the dash off previous and swapped speedos and tach.
all was working before pulled....now nothing is moving...
HOw does this thing get vacuum? does the car have to be running/on?
Thanks,
Ron
Old Mar 16, 2015 | 02:50 PM
Alan 71's Avatar
Alan 71
Hi Ron,
The engine is the source of the vacuum except for that stored in the vacuum tank on the left side apron. If hoses have been removed the engine must be started to restore the vacuum need to open the wiper and headlight doors.
The vacuum supply is from the fitting in the intake manifold right behind the carburetor. The rubber hose goes through a white plastic filter and then into a grey metal check valve.
2 hoses come out of the valve, a large hose which is the supply for the actuators, and a small which is the supply for the control side of the system, the switches and relays. It doesn't leave the engine compartment.
The small hose enters the interior through a 3 hole grommet in the firewall towards the right and slightly below the level of the master cylinder.
It runs to a T near the solenoid mounted to the rear of the tach. It then continues on to the switches and vacuum overrides.
Regards,
Alan
Willcox has good vacuum diagrams and so does the AIM.
Old Mar 16, 2015 | 04:16 PM
Factor's Avatar
Factor
Hi Alan!
Figured I would repost it as a clearer question...
OK...so I do not have it hooked up to the engine!...that hose is going to the power booster!...unless I need a T hookup?
what color stripe does this rubber hose to the intake manifold have?
thanks!
R
Old Mar 16, 2015 | 05:49 PM
Alan 71's Avatar
Alan 71
Hi R,
The hose for the power brakes has nothing to do with the vacuum supply hose for the headlights and wipers. It is connected to a fitting on the carb.
The supply for the vacuum systems is from a small fitting in the manifold between the carb and distributor. If it's an original hose it's white striped.
What sheet are you looking at in your 69 AIM?
Regards,
Alan
You can see the fitting in this picture.
Here you can see the single hose, the filter, the check valve, and the large and small hoses coming out of the valve. You can see the small hose passing into the interior through the firewall.
Old Mar 17, 2015 | 03:41 PM
Factor's Avatar
Factor
Hi alan!
Yes...i see the fitting...Zip corvette sent me a T fitting for the power brakes and vacumm hose off the manifold...?
I do not believe I have those check valves...will look...
Thanks,
Ron
Old Mar 31, 2015 | 12:41 PM
Factor's Avatar
Factor
THANKS ALAN!
Got this from Justin at Zip Corvette!
Hoping to get things up and running this week and working
if not, will be checking engine vacuum...
THANKS!
Old Apr 2, 2015 | 04:25 PM
Factor's Avatar
Factor
OK! working!!!
soo....what does it mean when the engine goes to LOW idle...and the headlamps just slowly pop up? is this a precaution? when the engine revs...they go back down...
happens with the wiper door too, but not as much...
thanks,
R
Old Apr 2, 2015 | 04:42 PM
Alan 71's Avatar
Alan 71
Hi r,
The headlight doors and wiper door should stay where they are at low idle, any rpm, if the engine is shut off, or has been off and is started.
I don't know what to suggest except to check the hose routing again, the operation of the check valve, and then the operation of the switches and relays.
Regards,
Alan
Low vacuum can cause the system to act odd.
Old Apr 3, 2015 | 12:25 PM
Factor's Avatar
Factor
yeah...i think that is it...my vacuum goes down to 12 or so when at idle...
when I rev it, they return to normal...
500hp engine 454...
any idea how to check if the stock vacuum air filter or check valve are bad??
thanks!
R
Old Apr 4, 2015 | 02:16 PM
Factor's Avatar
Factor
Old Apr 4, 2015 | 02:53 PM
Peterbuilt's Avatar
Peterbuilt
Default How to test:
http://www.corvette-101.com/vacuum.htm#check
Old Apr 4, 2015 | 09:40 PM
Factor's Avatar
Factor
Thanks! Great website!
R
To Vacuum system on 1969???
