rear strut replacement
Any suggestions on this job or should I leave well enough alone?
Hope you don't have to do this but it works.
At ~$30 per shock mount this isn't the best option, but for me, it was the only option.
There is a kit you can buy from napa for removing and installing harmonic balancers, foe engines, and that tool will thread straight on.
The trick is, once the tool is threaded on, you need to put a heavy object, like brake rotor or some heavy chunk of metal, on the back side of the ears, before! you pound the shock mount off. This allows the ears to not absorb any shock from when you strike it. If you do it this way, it protects the ears from breaking, and you don't loose any impact through the chassis or control arm, once struck, and use a good size sledge hammer. Don't strike it with ought a heavy weighted chunk on steel, on the opposite side. Trust me, works every time..
[/QUOTE]
Your strut replacement could easily turn into a whole rear end build.
Correct! you do not need to cut anything...what you do need is patience, a little ingenuity, penetrating oil, the correct tools and the shocks and struts can be removed without destroying the mount....Replacing the struts is really not that bad a job...if you know what you are doing. Place a floor jack under the end of the spring on the side you are working on to relieve the spring pressure...make sure the jack cannot slip off the spring end. If you are replacing the stock type struts, do yourself a favor and use adjustable struts which deletes the camber plate and bolt for a solid mount (BTW OEM struts are weak and can bend from road hazards and do flex under load)...the actual strut rod or even better, competition adjustable struts with heim joint ends....these are the best. I have had the comp heim adjustable struts for years and they are so much better than OEM struts...stronger, Adjustable, NO BUSHINGS to flex which creates unwanted rear suspension movement...the rear feels solid and planted just driving down the road or carving up the twisties..little to no deteriotaion in ride quality as well.
If you need a tool to hit the mount you can by a pipe cap (5/8" NPT maybe) at the hardware store for a couple of $.
I got 1 of my shock mounts off but bent it. I sawed the other one apart and sent both trailing arms to Van Steel in exchange for rebuilt units.
Rick B.
