Spark Plug Wires, Over or Under Headers?
Old Sep 15, 2015 | 06:45 PM
TedH's Avatar
TedH
When I installed the last set of wires on the C3, Taylor Spiro Pro 8mm's, I bought the set made for the car (80 L48).
Routed them under the headers using the stock 'v' heat shields and some of those nifty MSD 2-wire 8mm clamps, and the rear OEM 4-wire looms on the block (back by the distributor at back of engine). Combined, they all work together to keep the wires well away from the headers and out of harms way. Work great and keeps the appearance up top tidy.
NOTE: I have removed most of the emissions 'crap' on top and have minimal vacuum hoses to keep the engine running in tip top condition.
Old Sep 16, 2015 | 07:04 AM
labhound's Avatar
labhound
Default Spark Plug Wires, Over or Under Headers?
Mine had over the valve cover wires, I'll figure something out, it'll pop in my head while lying in bed probably....
Old Sep 16, 2015 | 09:22 AM
Street Rat's Avatar
Street Rat
Originally Posted by labhound
Well the last post was less than a year ago......
I'm needing some under header looms for my 454.. any ideas?
I've had my car running about six months now with the "Live Wires" which run under the headers. I'm sold on them.
Old Feb 21, 2020 | 03:08 PM
swajetmech's Avatar
swajetmech
1st Gear
I know its off subject but I Love your engine bay! What serpintine pulleys are you using? Looks like you have 4 pulleys. Power steering, crank, water pump and alternator. This would be my choice!
Old Apr 2, 2020 | 08:07 AM
Rob Via's Avatar
Rob Via
Originally Posted by 7t2vette
I went over the headers. I had to make the holes in the loom bigger to hold the bigger MSD wires.
What wire loom is this?
Old Apr 2, 2020 | 07:27 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
They are R&M Specialties 1101-P.
https://www.summitracing.com/parts/rnm-1101p
The wires are the universal MSD set that you make to fit, no pre-made set will fit that good.
https://www.summitracing.com/parts/msd-31239
