Differential question
Old Mar 21, 2015 | 03:29 PM
ndmick's Avatar
ndmick
Default Differential question
1971 small block coupe.Pulled Trailing arms off for rebuild .Side yokes on differential move in and out between 1/16 and 1/8 of an inch.Is this a problem I need to address?
Old Mar 21, 2015 | 05:24 PM
ndmick's Avatar
ndmick
I guess out it comes..
Old Mar 21, 2015 | 05:42 PM
Peterbuilt's Avatar
Peterbuilt
Default That's not good!
The end of the yoke inside the differential is held on by a "C" clip.
If the yoke wears down the clip can come off, so yes this is something you should address (sooner than later).
Old Mar 21, 2015 | 07:22 PM
ndmick's Avatar
ndmick
Old Mar 21, 2015 | 08:10 PM
cagotzmann's Avatar
cagotzmann
Can you measure with a dial indicator. Mine after replacing with a new yoke measured. .003 and .005 the other side. .005 is a OEM GM unit from 1990
so at 1/16 = .0625" may not be ready to replace, for a daily driver 1/16" is not that bad. @ 1/8 Its worth looking at. The bigger problem you will have is finding a good yoke as a replacement.
This is my experience
https://www.corvetteforum.com/forums...ide-yokes.html
Old Mar 21, 2015 | 09:31 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
As the clutch packs wear, the clearance increases. So you have the a combination of clutch wear and wear on the tips of the stub axles.
To Differential question
