Dial Indicator for Bell Housing Alignment. What ??
I understand what people are trying to do ( center the transmission with the crank to .005") but I see a flaw in the method described.
(go down to the last posts the flaw is I believed that the T56 Mounts to the bell housing similar to a TKO or factory 4 speed .... wrong)
You have this nice round hole in the bell housing that you are measuring against, but what does this hole have to do with the actual bolt holes where the transmission mounts on. If the bolt holes where not drilled in the correct diameter to the center line how does measuring the opening help ? If the opening is not centered but the bolt holes are why measure the opening.
What am I missing.? (The T56 is not the same as TKO's or factory 4 speed)
The only way I see this working is making an assumption the opening is perfectly cut based on the bolt holes. Since no one is measuring this it seems to be a useless process.
Show me the light if there is some.
Answer is.....
For T56 Bell Housing alignment use the following.
From Quicktime Instructions
"Special note for bellhousings that are designed for T-56 transmissions:
In order to check register bore run out on these bellhousings, you must remove the front plate from the transmission and mount it to the bell.
This will allow you to check
for run out by following the instructions below.
1. Remove clutch assembly from flywheel and install bellhousing
on engine block. (It is easier when you leave the clutch assembly off the flywheel.)
2. Install dial indicator base on the flywheel and adjust plunger to
contact the register bore of the housing.
This is the only thing I found that makes sense.
So how does measuring the opening in the bell housing help? You then must assume the bell housing opening is pefect ?
So does everyone use that assumption ?
The video I linked seems to make sense, and I think what you are talking about. Its the other methods people are using where they are measuring the bell housing opening with a dial indicator
such as this video. Its this measurment that doesn't make sense. Seems to be a waste since you are never measuring against anything on the actual input shaft.
How to Dial Indicate Your Bell Housing - YouTube
You're checking concentricity between the centerline of the crank and the center of that hole in the bell housing. That hole aligns the transmission with the crank via the input shaft bearing retainer which "should" be concentric with the bearing, and thus concentric with the input shaft.
This is the correct reason for aligning the bellhousing.
https://www.corvetteforum.com/forums...post1589191128
Dowels in the block align the bell housing to engine and the dowels in the transmission align the transmission to the bell housing.
I understand why you need to do this, its the method to determine what adjustments / measurements are required.
Measuring the bell housing opening seems to have a big assumption that dowel holes on the bell housing are a perfect relationship / centered with the opening and the dowels on the transmission are perfectly centered to the input shaft.
So from the 2 video's. The first one I believe is the correct way to measure, and the second video you must assume things.
On my T56 transmission the bell housing hole doesn't come into play with the alignment other than 2 dowel holes in the bell housing with the 2 dowels in the T56 transmission. Does your transmission align with the bell housing hole for alignment. If so I then understand why that works. If not it would be a assumption to something.
Its this assumption I am having a hard time with. That is why I understand what the person did in the first video by mounting the front plate of the transmission to the bell housing and measuring to the race of the input shaft bearing from the transmission. The other method requires an assumption the bell housing dowel holes and the transmission dowel pins are perfectly positioned.
It would be interesting to see both methods used to see if they come up with the same results.
So if the measuring of the bell housing hole is used when the transmission uses this hole for alignment I understand. I need to see how other transmission mate with the bell housing.
My T56 seems to require a different method to measure. Like the first video I linked too.
"OD of the input shaft bearing retainer on the front of the trans" this is the part I could not see on my T56 because I dont think it mounts the same and the bell housing hole is not a round shape.
I am using a quicktime bell housing.
http://www.summitracing.com/int/part...6023/overview/
I think I got it now.
Looking at a TKO transmission the hole is used for alignment, my T56 doesn't use this for alignment. Uses dowel pins. only.
I would then believe the factory 4 speeds are similar in mounting where the bell housing hole is used for alignment ?
Whew!
Old school Muncie trans. Look at the big flange around the input shaft. That is also the bearing retainer, and that is what locates the trans in the hole in the bell housing with a very precisie fit.
It all makes sense now. But looks like I cannot use this method to setup my T56 since I need to use the first video to do it correctly.
