coolant gauge always hot
Old Mar 22, 2015 | 12:25 AM
vette4plus3's Avatar
vette4plus3
Default coolant gauge always hot
Hi everyone wondering if anyone has come across this before, my 81 coolant gauge is always pinned on hot whether the car is running or not, when I turn the key to the on position it moves very little more to the hot side but its always way passed hot, has anyone come across this problem before? or can anyone post a wiring diagram of how the gauge is wired and where its wired to or what would pin it to hot? im guessing its a wiring problem cause the rest of the gauges seem to work fine, any help is much appreciated thanks
Old Mar 22, 2015 | 07:23 AM
65GGvert's Avatar
65GGvert
If it's pinned hot with the key off, it sounds like the needle has slipped on the shaft in the gauge.
Old Mar 22, 2015 | 11:41 AM
vette4plus3
is there a way to reset the needle and if there is where do I set it to, or do I need a new gauge
Old Mar 22, 2015 | 11:52 AM
mikem350's Avatar
mikem350
Ground the wire from the sensor and see if it moves. Also check with wire un grounded
Old Mar 22, 2015 | 12:46 PM
7T1vette's Avatar
7T1vette
Either the sender wire has a problem or the sender is bad. The probability that the gauge is defective is minimal, compared with the wire or sender.
Old Mar 22, 2015 | 01:39 PM
vette4plus3
do u know if the wires to the sender are supposed to have power or ground with key on, off, or running? I have a yellow wire and a black wire
Old Mar 22, 2015 | 01:40 PM
vette4plus3
does the sender communicate with the gauge directly or to the ecm, then the ecm goes to the gauge?
Old Mar 22, 2015 | 02:45 PM
1Hotrodz's Avatar
1Hotrodz
The sensor is a thermister, so... resistance decreases as temp increases. Most likely you have an shorted sensor or shorted circuit.
Old Mar 23, 2015 | 11:23 AM
65GGvert's Avatar
65GGvert
A bad sensor or shorted wire shouldn't peg the gauge with the key off. From reading his question, it sounds to me like it is always hot, then when he turns the key on it moves further to peg. That's the way I read it. If it only reads hot with the key on, the sensor or wire is a possibility, but not with it off.
Pull the wire off the sensor and see if your gauge drops down, if not, maybe a gauge issue. I have no experience with an ECM, so I can't answer the other question.
Old Mar 26, 2015 | 04:20 AM
7T1vette's Avatar
7T1vette
A gauge that is 'pegged' with the key ON will also be 'pegged' with the key OFF. The reason that it is 'pegged' is that there is a fault in the wire...most likely at the joint with the connector that attaches to the sending unit.
Old Mar 26, 2015 | 06:12 AM
65GGvert's Avatar
65GGvert
When he turns the key on, it moves higher. (according to his original post), If the sensor wire is shorted, I don't see that happening. Either way he can eliminate the sensor and wire by disconnecting the gauge and see if it's still hot. I hope he comes back with the fix for his problem.
Old Mar 26, 2015 | 02:27 PM
7T1vette's Avatar
7T1vette
There is absolutely NO reason to get into the gauge to diagnose the OP's problem. If the gauge moves when the key is turned ON, then the gauge is not at fault (it either works or it doesn't).
Since the gauge is functioning, the OP merely needs to remove the wire from the sending unit. Then, with ignition ON (engine not running), the OP can make two simple checks:
1) with sender wire removed (open circuit), the gauge should read at the high end of the scale;
2) with sender wire grounded to block (or any metal that is connected to chassis electrical 'ground'), the gauge should read at low end of scale.
Simple as that. If Test #2 fails (stays at high end of scale), the sender wire has an OPEN circuit....likely at the connection for the sender. If Test #2 passes, but the gauge still reads high, the sender is defective (it could already have an 'open circuit' inside).
Willcox (CF Vendor) has all this documented on his [Diagnostic] web pages. Good things to review BEFORE digging into the gauge cluster area.
Old Mar 26, 2015 | 02:35 PM
65GGvert's Avatar
65GGvert
If that's correct, the sensor is exactly opposite of any Vette I've owned (17). Shorting the wire should allow full current to flow and gauge read high and vice versa. One side of the gauge has 12v and the other goes to the sensor, so with the wire off there would be no current flow and the gauge read low. Are you saying that the natural state of the 81 is full hot and the current flow drives it toward cool?
Old Mar 26, 2015 | 03:11 PM
1Hotrodz's Avatar
1Hotrodz
I think you have this backwards grounding the gauge sending wire will pin the needle to the high side, and vice-a versa.
Old Mar 26, 2015 | 07:46 PM
65GGvert's Avatar
65GGvert
Thank you.
Old Mar 27, 2015 | 02:23 AM
7T1vette's Avatar
7T1vette
You are correct, 1Hotrodz. I rechecked the Willcox site and grounding the sending wire will send gauge 'high'; open circuit will read 'low'.
The tests are the same but the responses are just reversed. In any event, you still DO NOT need to dig into the cluster to diagnose your problem...and the problem is NOT the gauge. Either the wire or the sender, as I indicated in my first post.
Good luck with your testing.
Old Mar 27, 2015 | 05:02 AM
65GGvert's Avatar
65GGvert
I guess that means the post right before 1Hotrodz was correct about that too? And you are also saying that absolutely no way can the needle have slipped on the shaft of the gauge causing it to read higher than it should, and then go high to peg when the switch is turned on? I sure hope we find out either way what the issue is. If we could get him to pull the sensor wire off and see if the gauge drops down, it would help clear this up.
I don't know if you noticed or not, but the original guy has posted a new thread saying he didn't get anything from this one?
To coolant gauge always hot
Old Mar 27, 2015 | 07:44 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Pinned to hot usually means one of two things.. the gauge ohm circuit is grounded out or the resistor on the back of the gauge is blown. This will depend on what the face tells you.
Temperature Gauge, will read like this with a blown resistor
Temperature Gauge, will read like this with the resistance (ohms) wire grounded out 1968-1982
I've not read above due to time constraints this morning.... but pull the wire off the sending unit with the key on and see if the gauge goes back to cool. If not, and based solely on the fact the car is a 1977-1982 I would pull the cluster and check the PCB connector in the center of the dash.
The fingers on the board have a history of coming loose and touching each other. This could be your issue. I know the video below is for a 1968-1976 but it works exactly the same for the 68-76 cars.
If you wish to know how to bench test the gauge use these inputs.
Testing a 68-76 Temperature Gauge -or- What your non working gauge can tell you!
65-67
68-76
Old Mar 27, 2015 | 08:05 AM
0Willcox Corvette
Former Vendor
Originally Posted by 65GGvert
Thank you.
You were probably thinking of the fuel gauge circuit which is exactly the opposite. The best way to keep this sorted...
When ohms is missing from a gauge, it always goes to what you want the most.
Temp gauge = cool
Fuel gauge = full
Oil pressure = maxed
Oil temp = cool.
and it's just the opposite for each gauge when they are grounded out.
Can the needles slip on the gauges... Highly unlikely. Gauges that appear inaccurate are usually this way from faulty input or they have been calibrated wrong since new.
The needles are press fit and they can be pretty hard to remove at times. We use a cocktail fork that has been specially bent to remove the small gauge needles. The only time we remove the needle is if we are replacing a face (really no need now since the cost of a new gauge is cheaper then the labor and the face) or if the gauge is just no accurate and needs to be re-set.
Old Mar 27, 2015 | 08:10 AM
vette4plus3
hey everyone, I pulled the connector off of the sensor and the gauge stays where it is, the new gauge that I put in did come already in the hot position, im going by the picture that is on Wilcox website that shows exactly where my needle is sitting which says I have grounded ohms, with the key on or key off or running the needle does not change it always on hot and when you turn the key on the needle moves slightly, I will start checking the wiring and I will repost with anything I find
