Did GM make 2 different timing tabs?
Old Mar 22, 2015 | 11:06 AM
Tecdiverfl's Avatar
Tecdiverfl
Default Did GM make 2 different timing tabs?
I have a 67 impala impala built as a restmod. They used original block and I believe original timing cover but the balance it an aftermarket Summit. When I found tdc I was off about 12-14 degrees to the mark on the timing tab. When I compare the location of the tab to one on my 70 Vet is much higher uo. I went out and bought a Mr. Gasket tab and over lay on the vet and matchs perfectly in the impala its about 12 degrees off. The Impala has the tab spot welded to the timing cover.
Old Mar 22, 2015 | 01:31 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
There were several versions of timing tabs/balancers. Also different sized balancers.
Easy way is to find true TDC and remark the balancer unless it's a degreed piece.
JIM
Old Mar 22, 2015 | 02:03 PM
Solid LT1's Avatar
Solid LT1
Different diameter balancers require different tabs......ALSO very important change form 1968 to the 1969 Model year in position of TDC mark on harmonic balancer to allow better view of timing tab with new longer water pumps getting installed on passenger car motors....the tab was also relocated on the timing cover if you mix the wrong balancer with the wrong timing cover without checking for true TDC....big problems!
Old Mar 22, 2015 | 03:13 PM
mikem350's Avatar
mikem350
JIM
Spend the time, remove #1 plug and make sure its at TDC!!!
Then you can play with the pointers or balancer and never wonder again!!
To Did GM make 2 different timing tabs?
