Changing LSA
Old Mar 23, 2015 | 01:02 PM
c66vet's Avatar
c66vet
Default Changing LSA
Looking for feedback on advancing a cam. I want to know what will happen if I install a cam that has a 109 LSA and install it at a 112 LSA.
Will installing the cam at 112 LSA lower the power band and smooth the idle out. Or the difference of 3 degrees between 109 and 112 degrees is not noticeable at idle. Strange question I'm sure.
Old Mar 23, 2015 | 01:06 PM
MelWff's Avatar
MelWff
You cannot change LSA it is ground into the camshaft. What you can do is advance or retard a cam. Read these two links.
http://www.compcams.com/Pages/413/ca...ion-angle.aspx
http://www.superchevy.com/how-to/eng...formance-test/
Old Mar 24, 2015 | 06:13 AM
c66vet's Avatar
c66vet
Thanks for the feedback.
Old Mar 24, 2015 | 06:18 AM
c66vet's Avatar
c66vet
I was trying to determine how rough/radical the idle would be with this cam in a 540. Cam spec's 250/254 @.50, 714/680 LSA 109.
Old Mar 24, 2015 | 09:38 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Hmmmn...that depends on your idea of rough and radical.
I ran a 266/272 on a 112 in my 540 for years and considered it sort of "wussy" sounding even with 11.5 compression. Ran like a **** though! It idled around 1100 comfortably...could go lower...but I liked it there.
I've got a little 248/248 on a 114 in it now with the twin turbos. Interestingly doesn't sound a whole lot different to me,,,but I took out 2.5 points of compression also.
Is this a solid roller or a hyd roller?
Either way, I wouldn't expect it to idle bad at all. It will have very sharp throttle response and strong mid range pull.
What trans will be in it...stick or auto?
JIM
Old Mar 24, 2015 | 11:27 AM
1Hotrodz's Avatar
1Hotrodz
Advancing/ retarding the cam will change the intake centerline.
Old Mar 24, 2015 | 06:04 PM
427Hotrod's Avatar
427Hotrod
To specifically answer your question....retarding the cam from a "straight up" installed ICL of 109 to 112 (assuming this IS a 109 LSA cam)...you'll move the powerband upwards...not downwards. It will likely make a little more HP at higher RPM...a little less at lower.
3* won't typically move things a lot...but it will show the trend.
You'll still have the same overlap...yet with a later intake closing point...which will tend to lower cranking compression slightly and possibly make it idle a little worse.
Nothing dramatic...but typically that's the wrong way to go. Advancing it would build cylinder pressure at lower speeds an increase vacuum by closing intake a little earlier...which tends to help low speed operation.
JIM
Old Mar 26, 2015 | 07:39 AM
c66vet's Avatar
c66vet
Thanks for all the helpful input. I plan to leave the cam as is at 109 LSA.
Using a 5 speed transmission.
To Changing LSA
