1975 Window Tracks
Old Mar 24, 2015 | 09:19 PM
NothingSpecial's Avatar
NothingSpecial
Default 1975 Window Tracks
1975 Coupe.
I blew apart my door at work the other day thinking it'd be a simple job to fix the hinges and get the window to roll up. Needless to say, I drove home without a door that day on the freeway; When I came back to pick up my door, someone moved all my parts and I think some pieces got lost
I cant seem to figure out why my window tracks dont line up with the top of the door. Is there an alignment plate missing for the rear window track like the front one has? The bends are really weird for the left side, I'd think it should be straight like the front is. The bend looks factory though. No wonky marks on the metal.
http://s78.photobucket.com/user/the5...vyhol.jpg.html
http://s78.photobucket.com/user/the5...iprgb.jpg.html
Thanks!
Old Mar 25, 2015 | 07:10 PM
DUB's Avatar
DUB
The front track has a plate that attaches to the top of the track....The rear track DOES NOT.
DUB
Old Mar 25, 2015 | 09:34 PM
Peterbuilt's Avatar
Peterbuilt
That looks bent on the left side.
Old Mar 26, 2015 | 07:00 PM
DUB's Avatar
DUB
It IS bent.
DUB
Old Mar 26, 2015 | 07:26 PM
corvette74's Avatar
corvette74
Here is a pic of the plate DUB was referring to
Old Mar 27, 2015 | 09:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Before you blew apart your door, did you purchase the assembly instruction manual (AIM)?
With your door blown apart, the AIM could be helpful in putting it back together since it shows how all the door glass hardware was installed, the orignal GM part numbers for everything, and instructions for setting the door glasses.
Old Mar 28, 2015 | 02:03 AM
NothingSpecial
I have the AIM. I just figured that there might have been a later revision that got missed. Glad that mystery was figured out. I had time to look at it again, it has a hairline mark for it being bent. It's just so perfect though it looks factory. Now only if i can bend my motorcycle exhaust mounting brackets just like that...
Going to take a torch and see if i can bend it back. Thanks!
To 1975 Window Tracks
