While I'm in there....
Old Mar 25, 2015 | 01:34 PM
C3_ERROR's Avatar
C3_ERROR
Default While I'm in there....
Yeah one of these. I have the complete interior apart including the dash. While I have the dash out should I change out the heater core or is it best to leave sleeping dogs alone?
And if I do change it, which heater core do you recommend? I read on a few parts suppliers pages reviews that the heater core is too small and doesn't fit.
I have an A/C car so should I replace any of the A/C parts while I'm into the heater core? The A/C currently doesn't work because I'm not getting any power to any of the gauges or controls (which is why the dash is out) but "might" work once I fix the power issue.
Old Mar 25, 2015 | 02:06 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I would change the core if you are that far apart. I carry a correct copper core in stock too.
http://willcoxcorvette.com/product_i...roducts_id=752
But what year is the car?
When you have the heater box out of the car there really isn't any ac stuff to replace on the inside of the box. I have a troubleshooting page on the site for the AC heater controls, but again I'd need to know what year the car is.
Willcox
Old Mar 25, 2015 | 06:19 PM
hugie82's Avatar
hugie82
I would change the core.
Old Mar 26, 2015 | 09:04 AM
C3_ERROR's Avatar
C3_ERROR
Willcox
Sorry it's a 1975.
As for the A/C parts I was kind of referring to the vent door, actuator and other things I might not know about.
Old Mar 26, 2015 | 09:12 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Heater
While you are there, change out the seals on the A/C box. If you change out the heater core, make sure your new core does not leak. You can do this by putting the core underwater and filling it with a supply of low pressure air and looking for bubbles. I have had new cores leak out of the box. Jerry
Old Mar 26, 2015 | 01:37 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
If you do decide to change the heater core be sure to order the 'molded' hoses as the auto parts hoses will kink.
Also when installing the new hoses be very careful not to move the fittings on the new core as you can break the connection.
For the electrical problem:
Start be making sure the 'heater' fuse can pass power from one side to the other.
You need the key 'on' to power up the heater controls.
75 schematic:
https://docs.google.com/viewer?a=v&p...WRiNTdjNjdkNTQ
Old Mar 26, 2015 | 04:17 PM
C3_ERROR's Avatar
C3_ERROR
Perfect. This is just what I needed.
Old Mar 26, 2015 | 05:28 PM
0Willcox Corvette
Former Vendor
To While I'm in there....
