sediment in master cylinder ??
Old Aug 12, 2002 | 03:36 AM
razz1980's Avatar
razz1980
Default sediment in master cylinder ??
i changed my master cylinder cover today and when i removed the old one i noticed that there was sediment or something on the bottom..any idea if this is normal? should i be concerned? i tryed to move it a bit but it was thin like sediment so i left it..i use normal dot 3..i replaced my front calipers less than 100 miles ago and replaced with new fluid and my brakes work great..
Old Aug 12, 2002 | 03:39 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: sediment in master cylinder ?? (razz1980)
it's semi-normal. You can suck it out with a turkey baster.
Please, by the Mrs. a new one before Thanksgiving. If not that turkey is going to taste a little off.
Old Aug 12, 2002 | 03:55 AM
Darkness's Avatar
Darkness
Default Re: sediment in master cylinder ?? (BSeery)
It normally happens in older cars because of the oil sitting in the reservoir, you can clean that flushing the system with alcohol.
To sediment in master cylinder ??
