Kind of an amateur question but assembling flywheel, clutch, bell housing and transmission and double checking the type of locker I should use. Red being high strength and blue as medium.
I am guessing the following:
Flywheel to crank, Red
Clutch to fly wheel, Red
Bell Housing to engine, None
Trans to bell housing , none or blue.
I usually avoid red because I take stuff apart a lot. Only like to use on things that either are critical high vibration connections or connections that cant be easily accessed or checked from time to time.
Loctite red as in #272 which is high temperature, I don't use #271 on any automotive applications. I have air impact wrenches, never had problems with dis-assembly using this product, on the other hand when I crewed on a SCCA Trans Am car and picked up a bottle of #680 (Green) and assembled a complete front end suspension of a T/A car with it.......I was almost fired! We had to heat every part with an acetylene torch to disassemble it, that crew chief was trully PISSED!
