Jack Stand Placement
Old Apr 1, 2015 | 07:19 PM
Mereness's Avatar
Mereness
Default Jack Stand Placement
I am wondering where is to place 4 jackstands on a 78 vette? I would like to do some brake work, change oil, etc on my 78.
Thanks.
Old Apr 1, 2015 | 07:31 PM
caryb78's Avatar
caryb78
Pretty straight forward. 2 on each side. one forward just behind wheel on main chassis and one just forward of rear wheel also on main chassis.
Old Apr 1, 2015 | 07:32 PM
REELAV8R's Avatar
REELAV8R
Thanks.
In front of and aft of the doors on the frame rail. If were talking whole car in the air wheels off the ground you will need two more up on the front portion of the frame near the engine block to keep the front clip from sagging over time.
Old Apr 1, 2015 | 07:41 PM
Mereness's Avatar
Mereness
Thanks for clearing it up REELAV8R. I was wondering if I needed to put anything up by the engine. I won't have it in the air too long....maybe a few days.
Old Apr 1, 2015 | 08:30 PM
BKbroiler's Avatar
BKbroiler
You can put all the jackstands under the car you want, but you don't NEED any under the engine. I just took mine off the 4 stands under the side frame rails. It was there for three months, with no problems. I've done this many times. If your frame sags over time, you've got major problems.
Old Apr 2, 2015 | 07:48 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The owner's manual and the jacking instructions on the rear compartment door show the recommended points for jacking and jack stands.
Old Apr 2, 2015 | 10:06 AM
REELAV8R's Avatar
REELAV8R
That's interesting BK, you and I have the same year vette. Mine is a late 77 but should be the same in any case. I have zero rust on the frame, yet when I jacked mine by the frame rails only, the nose sagged over time. Not so as you would notice by looking at it, but the door gaps changed and that is how I became aware of it.
I've read here that many others have noticed the same thing. If the motor is out maybe not, but with the motor in it most definitely droops.
Old Apr 2, 2015 | 12:19 PM
BKbroiler's Avatar
BKbroiler
I think my car reacts similarly to yours, but the "sagging" occurs instantly and is just a normal result of the car's weight being supported differently than when its on the wheels. If I want to raise only the front end, I put my jack under the crossmember and lift till both front wheels are maybe 5 inches off the ground. I then put jackstands under the frame just behind the front wheels. When I let the jack down, the front end drops another inch or two after the frame is on the 2 jackstands and the front tires are only 2 or 3 inches off the floor. So, you could call that sagging, but really it is just flex due to the cantilever effect. I'm sure brand new 77s did the same thing.
Old Apr 2, 2015 | 02:14 PM
REELAV8R's Avatar
REELAV8R
Ok I see what you're saying. I jack mine in a similar manner. I use a piece 2x8 to span the cross member up front and jack it there. Then put jack stands under the frame rails. If I'm going to leave it that way though I do put jack stands under the front rails somewhere to support the weight of the engine.
Old Apr 2, 2015 | 03:16 PM
jim-81's Avatar
jim-81
I'm going to try that method (under the front cross member). Sounds a lot easier than a jack at each side behind the front wheels.
Old Apr 2, 2015 | 03:22 PM
BKbroiler's Avatar
BKbroiler
Don't confuse jack and jackstands. We only use one jack at a time.
Old Apr 2, 2015 | 05:19 PM
Sayfoo's Avatar
Sayfoo
Jack the front up under the center of the front cross member. Use a 2x4 block running length wise across the cross member to keep it from denting. I usually put my stands under the lower shock mounts. You can use a wood block here also if you want.
Rear, I slide the jack in behind the rear wheel and jack--again a wood block-- under the spring mount 4 bolts. Stands, again with a wood block, go diagonally across the frame at the kick up.
Old Apr 3, 2015 | 06:28 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
Personally, I never jack on a cross member front or rear. I put the jack under the side frame rails, just a little nearer the middle of the car than where I want the jack stand. Jack the car, slide in the stand, lower it. Then on to the other side. A few extra minutes but safer.
I had the car on four stands recently for a few days. As always with most cars, some sagging while it was up, but it returned to normal back on the ground. (Try closing a door of a “real” mini (that’s a Classic now I think) while it’s jacked. Now that is sagging!) It does look strange though, with the stands apparently a bit too close to the middle of the car. It looks as though it would be easy to tip it off at one end or the other. Thankfully, it isn’t!
Old Apr 3, 2015 | 12:44 PM
widowmaker221's Avatar
widowmaker221
Old Apr 3, 2015 | 01:17 PM
jim-81's Avatar
jim-81
good stuff... I like the wood blocks idea too. Seems like this topic comes up from time to time
To Jack Stand Placement
