Too many volts
Old Aug 12, 2002 | 05:40 PM
FeedVaal's Avatar
FeedVaal
Default Too many volts
I apparently am suffering from voltage regulator failure, the gauge read well into the red line this morning. Should I disconnect the alternator for the drive home?
Old Aug 12, 2002 | 06:25 PM
Larry B.'s Avatar
Larry B.
Default Re: Too many volts (FeedVaal)
No i wouldn't do that.... Assumming your drive isn't two hours at 70mph. Just watch the battery. It will get hot and could explode. It will vent hydrogen so the NO Smoking rule applies, unless you just like to go BOOM! :lol: :lol:
Old Aug 12, 2002 | 06:45 PM
45ACP's Avatar
45ACP
Default Re: Too many volts (silvervetteman)
I would NOT operate the car in that condition. No good can come of it.
Changing out the regulator or even swapping in another alternator is very easy.
Old Aug 12, 2002 | 06:52 PM
Cookwithvette's Avatar
Cookwithvette
Default Re: Too many volts (45ACP)
I agree. Not worth the risk for such a simple fix.
Old Aug 12, 2002 | 07:26 PM
IT STINGS's Avatar
IT STINGS
Default Re: Too many volts (Cookwithvette)
I was running a 140amp alternator and a week ago it melted some of my positive wiring and blew out all my light bulbs and radio and battery acid came out of the battery (very uncomfortable smell). I'm just glad nothing caught on fire. Do you have an extinguisher in your car???
Old Aug 12, 2002 | 07:40 PM
kbk212's Avatar
kbk212
Cruising
ihave the same problem swapped out alternater and still didnt help
let me know what you find i have not found my problem yet :confused:
Old Aug 13, 2002 | 04:25 PM
FeedVaal's Avatar
FeedVaal
Default Re: Too many volts (kbk212)
I swapped out the voltage regulator last night and ran the car for 5 minutes and looked good to go, gauge steady at 14v. Drive 10 miles to work and GEN lights up. So off to parts store at lunch for a rebuilt unit to swap out tonite. Did I kill it by not charging the battery fully before starting up? And why do I have a GEN light with an alternator? Shouldn't it read ALT? :smash:
To Too many volts
