77 engine install trouble
Old Apr 5, 2015 | 09:24 AM
spanishsilver's Avatar
spanishsilver
Default 77 engine install trouble
got engine lined up with motor mounts. front holes on mounts line up but it seems back of engine has to be lowered about 1/8 to 1/4 of an inch for them to line up in back. i installled bell housing bolts first and thought that may have been the problem so I loosened them. Do I need to take them out for engine to tilt back. thanks
Old Apr 5, 2015 | 09:32 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I'm not clear on the problem. Which motor mount bolts are you talking about?
Old Apr 5, 2015 | 09:33 AM
speedreed8's Avatar
speedreed8
seems i remember having a similar situation when i installed my engine several years ago with the th350 still in the car. i had to loosen the rear transmission crossmember and lower it slightly for them to line up then just jacked it back up and retightened.
Old Apr 5, 2015 | 09:37 AM
CA-Legal-Vette
I get you now. I've certainly had to do the same. Just be carefully of the fan shroud, the oil pressure sender and the distributor. None of the above like to be pressed against things.
Old Apr 5, 2015 | 09:44 AM
spanishsilver
so loosen the tranny mount inorder to lower tranny. this will also lower engine too if im correct. thanks
Old Apr 5, 2015 | 09:49 AM
speedreed8's Avatar
speedreed8
as long as all your transmssion to engine bolts are installed and tightened. i assume you have an automatic. yes it will lower the whole assembly
Old Apr 5, 2015 | 11:30 AM
spanishsilver
All fixed loosed tranny mount bolts and it slid in to position.. Thanks for the help. Now to hook up vacum lines and everything else.
To 77 engine install trouble
