71 AC evaporator change
Old Apr 5, 2015 | 03:42 PM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Default 71 AC evaporator change
Hi!
AC evaporator hose on my 71 vette broke and I can't get the evaporator housing off to get the evaporator out.
Is there any special procedure?
As the things look so far it seems like I will have to move the engine?!?!?
I removed the longtube headers but I still can't get it off.
The same goes for my heater core which is clogged. I just can't get it out.
Old Apr 5, 2015 | 04:56 PM
SWO vette's Avatar
SWO vette
The heater core can be removed from the inside of the car. Search for a you tube video on it. Also I just changed mine and while time consuming it was not that hard. To me the hardest part was getting the plastic duct back across to the vent hookup on the drivers side.
Old Apr 5, 2015 | 07:43 PM
TimAT's Avatar
TimAT
There are a couple of bolts from inside the car, along with some under the hood.
Old Apr 6, 2015 | 07:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm lost. You should be able to replace a bad hose without having to remove the evaporator.
To 71 AC evaporator change
