Too much carb?
Old Apr 7, 2015 | 11:07 AM
Killingsworth 73's Avatar
Killingsworth 73
Default Too much carb?
I have a 355 with unknown internals, other than a roller cam. I have an edelbrock RPM Air Gap manifold, and an Edelbrock 750cfm carb.
I think my primary issue is the accelerator pump not functioning properly/needing replaced.
If I accelerate 40% throttle, she drives fine, idles well, etc. If I slam my foot down when I'm under 3500rpm, rpms drop, car hesitates, and about a second later revs up and moves.
Do I have too big a carb? Do I just need to change my accelerator pump? I had the carb rebuilt a year ago, so new jets, etc. Don't think the accelerator pump was changed though.
Old Apr 7, 2015 | 11:42 AM
Shark Racer's Avatar
Shark Racer
If the accelerator pump is bad, the larger the throttle transition the worse the effect will be.
I'm assuming a sharp stab of the accelerator pedal also results in a similar, but less pronounced version of the issue? (say adding a sudden 1/4 throttle or something)
If so, fix the accelerator pump and try again. You need fuel enrichment on throttle transition as there is a delay in the time it takes for the metering circuits to respond to the new inbound air.
Old Apr 7, 2015 | 11:47 AM
JimLentz's Avatar
JimLentz
With the engine off do you see a squirt of fuel from the accelerator pump if you quickly move the throttle on the carb?
Old Apr 7, 2015 | 11:55 AM
Killingsworth 73
nope - used to
Old Apr 7, 2015 | 01:01 PM
7T1vette's Avatar
7T1vette
Worn, damaged, or missing seal on the accelerator pump. The ethanol in modern fuels will cause most synthetic rubber seals to swell and fall off the pump rods. That seal needs to be Viton or other type synthetic rubber that can tolerate ethanol.
Old Apr 7, 2015 | 01:08 PM
jb78L-82's Avatar
jb78L-82
I agree about the accelerator pump…FWIW my 355 L-82 with a roller cam .525 lift and AFR heads runs pretty darn good with a 650 CFM carb… I would think that a 750 CFM is a little big for a 355 but jetted correctly will run fine.
Old Apr 7, 2015 | 01:28 PM
Killingsworth 73
So you think run smaller jets after changing the accelerator pump and seal?
Old Apr 7, 2015 | 01:29 PM
OMF's Avatar
OMF
Those carbs (assuming it's a 1407) have a weighted air valve, or a spring adjustment on the secondary air valve just like the Qjet. That means it's a demand type of carb that will only supply the volume of air, and therefore the fuel that the engine wants/needs (If it was jetted properly.)
So your carb size is fine, and as others have said get the accelerator pump that is compatible with modern fuels and your hesitation should disappear.
Jets are easy to change on those carbs.....YouTube is your friend for that.
Old Apr 7, 2015 | 01:30 PM
augiedoggy's Avatar
augiedoggy
according to edelbrock the edelbrock 750 carb is designed for big block applications... 355ci is too small for that carb. I dont believe its an on demand carb that works like suggested... otherwise I wouldnt have seen so many threads and videos on changing jets and needles... I think the AVS series carb was more adjustable...
I just removed my edelbrock 600cfm carb from my new 355 and swapped in a street avenger 670 myself.... even holley suggests only using 750cfm carbs on hot 350 setups. and those will have less throttle response but better top hp numbers
the heasitation you describe happens when there is either too much or too little feul hitting the chamber when needed... if you accelerator linkage was adjusted wrong this could happen even if everything was working correctly. I kept getting rust particles in my edelbrock from my tank before adding a paper filter causing the accelerator circuit to not work correctly. I also had an issue with the ethanol eating the aluminum surface in the float bowls.
Old Apr 7, 2015 | 01:32 PM
jb78L-82's Avatar
jb78L-82
You would need to get the exhaust on an air fuel meter to know...
Old Apr 7, 2015 | 01:36 PM
Killingsworth 73
Shouldn't the Edelbrock's accelerator pump and seal be made out of this?
Old Apr 7, 2015 | 01:43 PM
augiedoggy's Avatar
augiedoggy
depends on how old it is (or the rebuild kit was).... remember the edelbrock is a weber carb that was later sold as a carter carb until edelbrock bought the rights and molds to make them in china and assemble them here... thats why they still have the weber markings on the side... they are ancient in design...
even my 3 year old edelbrock had constant issues with ethonal sitting in them... last year I have to scrap out the fuel which turned to clear jelly in the float bowls. I used stabilizer and had no issues this year with it sitting over the winter.
Old Apr 7, 2015 | 01:56 PM
7t9l82's Avatar
7t9l82
750 is not too big, i agree about the accelerator pump needing to be checked, it may even have some fuel coming out the squirter but not enough. get a replacemen thats resistant to ethanol as I've seen new ones go bad in a week.
Old Apr 7, 2015 | 02:14 PM
augiedoggy's Avatar
augiedoggy
ok depends on the model /jetting of the carb but a 750cfm carb as shipped from edelbrock is too much carb for a mild 355 engine that build for street use.(especially if its a 1411).. The track is another story... you can get better top end with this combo but at a cost like throttle response and drivability in most cases... if you jet the carb down to perform like a smaller carb you can overcome these problems but then we are not comparing the same thing are we since depending on the carb the only thing we are not effecting is the venturi size.
http://www.edelbrock.com/automotive/...erformer.shtml
Old Apr 7, 2015 | 02:20 PM
MelWff's Avatar
MelWff
everybody does recall that Chevrolet used a properly setup 780 CFM Holley with vacuum secondaries on the 70 to 72 LT-1 350 ?
Old Apr 7, 2015 | 02:38 PM
augiedoggy's Avatar
augiedoggy
I got nothing...other than I thought we were discussing an unknown 355 engine here with unknown internals besides knowing its a rollercam and not a 370-400hp LT1 and there were many many 350 engines that gm sold with smaller or "on demand" carb setups compared to the LT1... was the 780cfm really needed?
Old Apr 7, 2015 | 02:51 PM
jb78L-82's Avatar
jb78L-82
Good reading..but on a 383
http://www.superchevy.com/how-to/148...ey-carbs-test/
Not a whole lot of difference between the 600/650/750 carbs in terms of power…on a 383, not a smaller 350. Like I said earlier, a 750 Cfm carb will work but not necessary.
To Too much carb?
Old Apr 7, 2015 | 03:22 PM
Killingsworth 73
When mine was rebuilt, the guy said there was clear jelly in the bowls and jets! He said only time he'd seen that is diesel and gas mixing? Hmmmm..
Old Apr 7, 2015 | 03:27 PM
Killingsworth 73
My internals are an unknown, but I have a friend with a fully restored, all original 71 LT1 vert with a 4 speed, and I smoke him in a race every time. And I have 3.08's.
Also, weren't the 71's rated gross HP, and by 72 on rated on net?
Old Apr 7, 2015 | 05:00 PM
augiedoggy's Avatar
augiedoggy
I believe the jelly is from the aluminum they use.
Its likely some sort of chemical reaction. I had aluminum stereo amplifiers under my truck seat melt from salt in the wet carpet they were sitting on and they had the same slimmy ooz all over them were they were corroding...
