'76 driver side power window
Question - I can't see forking over $100+ for a power window harness set when I know the problem is only two wires that will probably cost me $10 and a 6-pack to get through the fix. I was unable to locate where the 2 wires come through the other side but I know 'bubba' has been in here before with electrical tape out the wazoo under/behind my dash. What I'm trying to find is where the two wires terminate within or outside the harness so that I can simply replace these two wires only with new ones. I plan to disconnect the 2 culprits and terminate (or pull out entirely if I can) and connect the 2 new ones and zip tie to the harness. Also - is there a particular brand of wire that is 'more appropriate' when replacing them?
Any help would be great.
Thx!
http://www.corvetteforum.net/c3/tune.../index22.shtml[url]
http://www.americanautowire.com/shop/power-window-switch-pigtail-wires
With the kick panel removed pull the broken wire out of the conduit (door boot) and splice on some new multi strand wire.
Feed the new wire into the boot and splice the new wire into the wires in the door.
