Power steering control valve
Old Apr 9, 2015 | 06:39 AM
Johnboy1969's Avatar
Johnboy1969
7th Gear
Default Power steering control valve leaking again
Hello, I am have trouble with the pscv. It leaked from when I bought the 80 corvette a year ago. To pass the uk mot system and get it road legal I need it not to leak. So I bought a rebuild kit and rebuilt. All good for a week or so and now it's leaking again. It's seems the steering fluid is coming through the ball stud and washing the grease away which I'm sure this is not meant to happen. I really want to sort this out and not purchase a recon unit if I can help it. Any advise please.
Old Apr 9, 2015 | 02:56 PM
MelWff's Avatar
MelWff
did the kit come with instructions such as these and you saw no corrosion or marks inside the bores?
http://www.cssbinc.com/images/ads/ho...structions.pdf
Old Apr 10, 2015 | 03:10 PM
Johnboy1969
7th Gear
Ok, I may try and rebuild again and double check with this info. Thanks
Old Apr 10, 2015 | 03:37 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Be careful greasing the valve as too much may damage the seals. I was told by a valve rebuilder to grease it sparingly and with the car running.
Old Apr 10, 2015 | 05:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a video we did on the rebuild, it may possibly help you.
Willcox.
Old Apr 12, 2015 | 06:21 PM
Sayfoo's Avatar
Sayfoo
Been there, done that. Either you had a poor quality kit, have a bad core, or you messed up. It is easier the second time. The above video helped me.
Old Apr 12, 2015 | 10:53 PM
0Willcox Corvette
Former Vendor
He may have cut the seal putting the two halves together, I know I've done it before. (probalby why I don't build the valves here, my guys do them all now).
If you go to the 8.15 mark in the video you'll see what I'm talking about.
Willcox
Old Apr 13, 2015 | 02:18 AM
Johnboy1969
7th Gear
Willcox
Yes thanks I have watched your video and will check the last bit of putting the valve bodies together as it was a pain but I guess that's the bit where it will leak into the stud side if the seal is not good.
To Power steering control valve
