Hooker side pipe headers
Old Apr 9, 2015 | 05:43 PM
cottoneg's Avatar
cottoneg
Default Hooker side pipe headers
Hi guys
I need a quite set of side pipes to run the car at Lime Rock. Burns mentioned it was possible. He asked the size of the header primary tubes. They seem to measure around and 1 ⅜ to 1 ½ to an inches. The car is a small block (350)
Does that sound correct? Does anyone know the actual measurement?
Old Apr 9, 2015 | 06:50 PM
cottoneg's Avatar
cottoneg
Originally Posted by cottoneg
Hi guys
Never mind guys. They are not square. about 1.45 and 1.55
Thought they were square and thought I was going crazy.
Old Apr 10, 2015 | 12:14 PM
MelWff's Avatar
MelWff
the only way you are going to pass the noise test at Lime Rock with side pipes is if you use the extremely power robbing reverse flow muffler insert.
http://www.summitracing.com/parts/ho...2hkr/overview/
Old Apr 11, 2015 | 08:07 AM
69ttop502's Avatar
69ttop502
Curious what Burns had to say on how to quiet the sidepipes down without losing a ton of power.
Old Apr 12, 2015 | 07:49 PM
3X2's Avatar
3X2
Possible to get another pair of tailpipes and cut off the mounting brackets and re weld them so the outlet points down instead of out?
Old Mar 29, 2019 | 07:06 PM
buckybadger45's Avatar
buckybadger45
I have a 1972 454 coupe that I bought new and wanted side pipes when I ordered it but they were not available (1969 was the only year they were offered for a C3). In 1978 after I had replaced the stock mufflers twice and needed to do so again I said this is nuts and contacted GM to see if they still made replacement side pipes for the C3 model. They did, so I ordered a set of pipes and covers, plus a backup set of pipes not knowing how long they would last, and had them installed. I should have done this when the car was new. They sound great, I have never noticed a loss in power, and with the covers on I can drive 100 miles, stop and put my hands on them they are barely warm. No chance of burning anything. And the best part is those originals are still on the car 41 years later. I have the extra set that I ordered in my basement, complete with the GM part labels still attached.
Old Mar 31, 2019 | 09:21 AM
speedreed8's Avatar
speedreed8
Answering A 4 yr old thread
To Hooker side pipe headers
