My 70 coupe was originally a Minnesota car and the frame isn't in the best of shape. It's originally a 350/350 4sp manual steering and brakes, non tilt wheel. I picked up a California 74 donor without engine trans or much interior but it had power steering, power brakes and the tilt wheel I need, as I got to looking at it the frame looks almost new and was probably repainted or powder coated. I'm not sure if it was originally an automatic but dang the frame is perfect. My question is; is the only issues the lower rear section body mount (I can shim right?), and drilling for the rear bumper?
Yes the 74 bumper system bolt to the frame but the holes line if with the holes on the 70. Do if desired a 70 frame could be used on the 74 and I think up to a 77 ( I'll defer as I'm still learning vettes ( gen 1 and Gen 2 camaro's I'm all over)
Hi A,
"Is this a good swap?"
It seems to be a swap of 'convenience' at this point.
I think it depends on what the rest of the car will be as to whether it's a "good swap" or not.
Some 70s would certainly be devalued by using a 74 frame. The further your car is from 'original' the less impact the 74 frame will have.
So it could matter not at all, or it could matter a whole lot.
Regards,
Alan
The original engine was replaced with a C coded (crate) engine from the factory probably sometime after 74. The frame is pretty rusty being from originally from The land of 10,000 lakes rain snow sleet and salty roads. The 74 frame I have is mint possibly powder coated. without the original motor the collector value was lost long ago. Besides I want ps PB and tilt, nothing that was originally on my 70. I'm building myself a fun driver, I've already picked up a set of performer heads wth rollers. B
Nothing to it,a bit of work with a cut-off blade then flap-disk in your angle grinder,then rework a couple of holes for the rear bumper brackets,the toughest part should be matching the paint or powder coat on your new frame.
Frames are the same up to and including 74. The only difference is the rear Bumper bolt holes and the Welded Nuts for the front Bumper braces. Also You will need to shim the body mounts to make up for the difference the frame mounts were lowered for the 73-up rubber mounts. Done this several times, 74 Frames are much cheaper than 69-72. Stan.
