Running Too HOT! Ideas?
1. 1972 base 350. Totally stock
2. Timing at 8 BTDC, 30 degree dwell, 600 RPM in drive.
3. Starts great, runs great, idles great.
4. Fan installed correctly, shroud in tact, sealing foam in place, new thermostat, new coolant.
5. Gas mileage is kinda crappy…maybe 90 miles on a half tank.
6. However, its gets pretty hot…
a. Gauge is useless as it shows something like 160 when totally warmed up
b. Using an IR Thermometer I get a reading of 230 on the intake manifold and 190-200 on the upper radiator hose.
c. Thermostat housing reads same as the intake manifold.
d. Hot restart results in erratic idle and near stall, but when given more throttle runs fine.
e. Notice that the heater core hose touches the steel fuel inlet line…could be heating up the fuel? Vapor lock?
PLAN:
1. I have not checked TOTAL timing and the old vacuum advance may not be advancing the timing.
2. May eliminate the heater core routing. I'd hate to do that as I like everything to operate as intended. I could re-route the heater hose.
3. Maybe have the radiator rebuilt.
YOUR IDEAS/EXPERIENCE/SOLUTIONS?
Thanks gents
- Water pump…hmmm…it is the original part. It could have failed I suppose.
- Air pocket is totally possible…replaced the heater hoses and drained off half the coolant. Also replaced the intake manifold and gasket.
- No oil in coolant.
- Radiator…seems to be the likely source, but I would like to eliminate the other possibilities too. So this is good stuff
Look for bubbles in the coolant.
I do not use factory timing specs. I have mine set to 14* at idle. More advance can help cool things off.
I have a 180* tstat. When I point a laser thermometer at the tstat housing it reads 180* and my gauge is right around 180 also so you are right not to trust the gauge.
I hope you get this one figured out before it gets to hot out.
At highway speeds (high load), suspect radiator efficiency as you should have sufficient airflow across the radiator.
This is the starting point for me. I like AC steel fans and thermo clutches. A good stock water pump will do the job; I've had good luck with Flow Kooler pumps.
I have the re-cored original Harrison in my L36.
The impeller on the water pump could be ineffective due to cavitation erosion or scale buildup. Also, it doesn't take much scale to drastically reduce the thermal efficiency of metal, so depending on how diligent one has been replenishing anti corrosives in the coolant that could be an issue.
I have personally just switched to Evans waterless coolant after tiring of coolant flushes and replacing heater cores on old cars. Hope this helps...
PLAN:
Thanks gents
Can you feel the air movement engine side of fan ?
My GTO did this got hot stayed hot, I replaced everything.
Clutch fan was not enough air moving through the radiator
1. Water Pump
2. Radiator
3. fan clutch
4. thermostat
5. antifreeze
6. belts
7. hoses
8. heater core
9. rad cap
check check check ..................
Good luck.
I verify temperature gauge by removing sending unit, from car.
use a long 120v ext cord....... "DO NOT PLUG IN !"
add a couple jumpers, use 1 ext. cord conductor for gnd going to your sending unit, use the other conductor for gauge feedback,
make connections at stove and car, setup on the stove, in pan of water, turn everything on, boil water in pan with sending unit,
your car gauge should be 212 degrees F at boiling point.
your gauge is now verified reading correct temperature, ...if not get the correct sending unit.
