manifold heat ports
Old Apr 13, 2015 | 07:28 PM
rugerm44's Avatar
rugerm44
Default manifold heat ports
I had to pull my intake off and saw that it has the heat ports for heating carb.what years didnt have these.I want a gasket without the provisions so as to block it off. My gas vaporizes in bowls.I put on a heat shield between carb and manifold.It helped some.
Old Apr 13, 2015 | 07:46 PM
gve's Avatar
gve
Most intake gaskets have a metal plate included that you can install over that port to block the exhaust heat. It will also help to not burn the paint on your intake if you have a painted intake.
Old Apr 13, 2015 | 08:40 PM
rugerm44's Avatar
rugerm44
Thanks.I can hear it boiling in float bowls and watch fuel drain into carb after 15min of sitting.
Old Apr 14, 2015 | 01:35 AM
7T1vette's Avatar
7T1vette
Most intake manifold gasket kits come with blocker plates that can be inserted with the gaskets to block off heat-riser exhaust flow. If you don't make many cold-weather starts with your car, it's a good idea to install those blocker plates. It's also a good idea to cut off the heat-riser valve in the right-side exhaust manifold outlet. If that 'puppy' gets stuck in the closed position, you can have some real nasty engine damage.
Old Apr 15, 2015 | 05:41 PM
rugerm44's Avatar
rugerm44
I have headers and an electric choke.Found gasket set with plates with small hole in them.put aluminum over them to cut off completely.
Old Apr 15, 2015 | 06:02 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Fel Pro makes them already blocked off.....
P/N 1204
http://www.speedwaymotors.com/Fel-Pr...FcIdgQodrT0Ayw
Jebby
To manifold heat ports
