transmission
Old Apr 17, 2015 | 03:52 PM
Pancho07's Avatar
Pancho07
Default transmission
I have a problem with my transmission. I ran over the tread of a truck yesterday and it hit something under my 77 vette. It put the transmission in first gear and it will not come out. The shifter moves but it feels like something is broken. It is a cable and where would it hook to transmission>
Old Apr 17, 2015 | 03:57 PM
BKbroiler's Avatar
BKbroiler
Automatic or manual? Auto trans has a cable connected on the drivers side of the trans. If manual, some of your linkage probably got bent.
Old Apr 17, 2015 | 04:03 PM
Pancho07's Avatar
Pancho07
Automatic. Thanks , I will see what I can find.
Old Apr 17, 2015 | 07:49 PM
diehrd's Avatar
diehrd
Yes get car in the air and check the shift cable/linkage as stated on drivers side.
Old Apr 17, 2015 | 08:04 PM
Pancho07's Avatar
Pancho07
Got the cable out. Didn't know it made an S turn above the transmission. Now just have to find a new one and get it back in.
Sure had me worried when it slammed into first gear driving down the highway at 60mph.
Old Apr 21, 2015 | 07:36 PM
Pancho07's Avatar
Pancho07
Got the new cable in. Now can someone tell me how to adjust it?
Old Apr 22, 2015 | 07:57 AM
gungatim's Avatar
gungatim
Put it in park manually on the trans, put the shifter in park, tighten it up. then put shifter in L1 and make sure it matches the detents. shouldn't take much...the detents in the trans are positive for each position. if you've ever hot-wired a car, this is how you would manually put it in gear after twisting the steering wheel to break the cam lock...they never show that on tv...
Old Apr 22, 2015 | 10:14 AM
Pancho07's Avatar
Pancho07
But the question I have is if it doesn't match up, and it doesn't, how do you adjust the cable? I keep hearing adjust the cable but haven't seen how that is done.
Old Apr 22, 2015 | 12:31 PM
gungatim's Avatar
gungatim
I don't believe there is any adjustment built into the cable. the bracket may be bent, or I have heard some aftermarket cables are not made correctly. Is you'rs a GM part?
Old Apr 22, 2015 | 12:35 PM
hugie82's Avatar
hugie82
There's a little adjustment on the trans shift lever. I usually place it in low1 and do the same with the shifter. That usually gets you very close to perfect. Just make sure your car locks into park when finished.
Old Apr 22, 2015 | 01:56 PM
Pancho07's Avatar
Pancho07
Thanks. I might be using a too small hammer.
Old Apr 29, 2015 | 07:46 AM
diehrd's Avatar
diehrd
Put trans in N .. Make sure bracket is on the correct trans pan bolts .. Install cable with shifter in N ..
Old Apr 29, 2015 | 09:59 AM
bashcraft's Avatar
bashcraft
That's usually the case.
To transmission
