accel pump replace L-82 quadrajet
Old Apr 20, 2015 | 03:57 PM
caryb78's Avatar
caryb78
Default accel pump replace L-82 quadrajet
Do I have to remove the carb to replace the accel pump. Any thing special I need to know? I have the parts from Cliffs.
Old Apr 20, 2015 | 05:19 PM
jnb5101's Avatar
jnb5101
It's only a matter of convenience. I find it's easier having the carb on the bench so that the control rods and screws don't get dropped into weird places. Plus my back starts to ache if I lean over the engine for any length of time.
Old Apr 20, 2015 | 07:09 PM
7t9l82's Avatar
7t9l82
i agree, i prefer on the bench.
Old Apr 22, 2015 | 12:38 PM
7T1vette's Avatar
7T1vette
If you are experienced...and careful...it's no problem changing the accel pump with the carb on the car. Otherwise, it would be best to remove it.
Old Apr 22, 2015 | 12:47 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
7t1 gave you great advise
Old Apr 22, 2015 | 07:02 PM
caryb78's Avatar
caryb78
Default accel. pump replace
Well I went ahead and removed the carb. Good move! Gasket between top and center body was torn to the edge in several places. Base plate was wrong. Hanger for metering rods was bent slightly and several loose screws. Purchased a kit and fixed everything including the accel. pump which was the original task. What a difference it made. Thanks for all the responses.
To accel pump replace L-82 quadrajet
