Brake Piston Problem??????
Old Aug 13, 2002 | 10:38 PM
SuperFast80's Avatar
SuperFast80
Default Brake Piston Problem??????
I was changing the pads and after taking off a pad on the front left wheel, one of the pistons came out of its seat and peed fluid everywhere.
Is the seal f-ed or can I put it back in there and put the caliper back on the rotor? The rings seem to be in good shape but.....
Help!
Old Aug 13, 2002 | 11:23 PM
Jvette73's Avatar
Jvette73
Default Re: Brake Piston Problem?????? (SuperFast80)
The inner seal may still be ok. It must be that the outer part(dust boot) is kinda loose and allowed it to come apart. If the dust boots are tight like on a newly rebuilt caliper then the pistons will move outward, from the spring pressure on them, when the pads are removed but the boot will hold them from falling completely apart. Slap it back togeather and bleed and give it a go. Got nothing to loose in my opinion.
Make sure you pop the outer seal off carefully so you can verify visually that the inner seal goes back in with the lip facing the right way. You dont want to just blindly cram it bavk in there or the seal lip could become reversed or kinked. The inner seal should taper inward. Once its back in place push the dust boot back in place.
[Modified by Jvette73, 9:27 PM 8/13/2002]
Old Aug 14, 2002 | 12:12 AM
75Rag's Avatar
75Rag
Hey Flav, I can't be of any help but really....
I didn't mind buyin' breakfast.... :D
Good luck
Old Aug 14, 2002 | 10:32 AM
SuperFast80
Default Re: Brake Piston Problem?????? (Jvette73)
Jvette, I guess I have to bleed the whole system before I give it a try then?
Old Aug 14, 2002 | 11:54 AM
SuperFast80
ttt
Old Aug 14, 2002 | 04:02 PM
john's '81 mouse's Avatar
john's '81 mouse
you may get by with just bleeding the wheel of the caliper which had the piston pop out. believe you are to put a light coating of rtv on outside of the dust seal when you re-install, so area must be clean and dry on both caliper and seal edge, personally, I'd get a new dust seal, can be purchased at auto zone.
To Brake Piston Problem??????
