I replace the one in my 69 a few years ago during a conversion from factory air to a Vintage Air system. It was not too bad at all, had to pull the hood and I pulled the evaporator and radiator out which gave more room to work the old one out and new one in. I believe my new replacement support came from Wilcox one of the great forum vendors.
Thought the second pic would help of the old support, mine was rusted out on the bottom.
If you haven't yet do it now, brace up your front end at the points where your support came out of. Your rad support actually helps keep the top of your fenders from sagging in. A 2x4 across the points where your support can out of should do it. I had my support out for a few weeks and had a hard time getting it back in because of the sagging.
73-76 early support is one of the hardest there is to change out.
We remove the hood for additional clearance. If you don't you'll have issues clearing the shroud out from around the front suspension. This job just takes time and patience more than skill, and be careful not to damage the condenser or the radiator when you do the work.
