Differential removal?
Old Aug 14, 2002 | 08:51 PM
Duke94's Avatar
Duke94
Default Differential removal?
Can I remove the differential and housing as an assembly still bolted to the cross member? I have everything off the diff and loosened the 2 bolts that hold the cross member to the frame, but the cross member does not seem to move down. What have I missed?
Old Aug 14, 2002 | 08:54 PM
ORVette's Avatar
ORVette
Default Re: Differential removal? (Duke94)
Nothing-it's just a BIT..!!!to move. Try a big pry bar and a hammer. Don't worry, when you think your trying too hard, it's not hard enough.
Old Aug 14, 2002 | 08:56 PM
FeedVaal's Avatar
FeedVaal
One word...PB Blaster....wait, is that two words? :cheers:
Old Aug 14, 2002 | 09:20 PM
Tom77's Avatar
Tom77
Put a floor jack under the rear for support. Use two crow bars one on each side of the bushings and work the crossmember back and forth. Use some wd40 or pb blaster on the bushings. It takes some work to loosen it up. Some people have used gear pullers to remove the crossmember. The bushings are expensive if you have to replace them.
To Differential removal?
