check ps fluid help please
Old May 9, 2015 | 08:31 PM
allena's Avatar
allena
Default check ps fluid help please
Hi
75 vette with ac, PS, auto trans, stock
I tried to check my power steering fluid today & the alternator support is
in the way.
Is there a way to check it without needing to remove the alternator support?
This seems too hard to do
Thanx
A
Old May 10, 2015 | 01:52 PM
dochorsepower's Avatar
dochorsepower
Allen, I have a '75 and yes it's a pain but after loosening the dipstick I can angle it out. Check to see if you have the correct original type part and belt. The wrong pump with the wrong reservoir could be a problem.
Old May 10, 2015 | 01:55 PM
arklacat's Avatar
arklacat
St. Jude Donor '16-'17,'19
Mine's an 81 so maybe not apples and oranges but i have the same situation. It is tough to get the cap and dipstick out but i can by tilting it around. It wont pull straight out. Im not home so i cant check to give you specific details.
Old May 10, 2015 | 03:54 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
It's been that way since 68.
my 68 is the same way.
Get a bright light and look down
into pump with cap tilted out of the way.
If you see fluid in the neck area your fine.
Marshal.
Old May 10, 2015 | 06:27 PM
BKarol's Avatar
BKarol
Same on my 78. After you unscrew the cap you need to remove it sideways toward the firewall. Not straight up to get a reading. 10 years ago I got a dipstick and made a few bends to match up to the cap. Etched full hot and full cold on it. Now once the cap is removed I just rest the bend on the rim of the reservoir like the cap would and take the stick straight up. Haven't looked for any other alternative since:
Old May 11, 2015 | 05:41 PM
AboveTheLogic's Avatar
AboveTheLogic
I usually just fill it until it spills out and then clean up the mess, but that's me
Old May 11, 2015 | 05:47 PM
hugie82's Avatar
hugie82
been there done that many of times but that's the fun of owning a C3
Old May 11, 2015 | 07:37 PM
gjohnson's Avatar
gjohnson
Got to pull it out thru the backside(firewall)Not hard at all. I use a flashlight to check level then use a long funnel and pour in small increments so I don't make a mess.
Old May 12, 2015 | 05:43 PM
C3Hawk's Avatar
C3Hawk
I have a 1975 and could not remove the PS cap. No way was it coming out. Simply no way. I got tired of dipping clear tubing with my finger on the end to check the level. So one Saturday I kept testing belts in 1/2" increments til I found one that worked (i.e. allowed me to finagle the cap off yet didn't have the pump too far out rubbing against the frame.) I still have the NAPA list for the belt lengths somewhere if you want them. Just tell the store you might be back a couple times exchanging belts that day.
To check ps fluid help please
