Dumb Question.....Help Please (Again)
Old Aug 14, 2002 | 11:03 PM
bsowa's Avatar
bsowa
Default Dumb Question.....Help Please (Again)
I am so freaking frustrated tonight.
Regarding my power steering pump.....what else. For the bottom outlet hose, there are two seperate nuts, a small one that connects the hose to the pump, then a quite larger one that the hose goes into. (I would take a picture but it got too dark on me)
When I am disconnecting the hose (or trying to like I did all night) what nut should I be loosening. I have been trying the smaller one (that is actually connected to the hose) I have had NO LUCK on that nut. It looks like I started to round it off so I quit for the night.
Is that the nut I should be undoing?
Thanks guys.....
Old Aug 14, 2002 | 11:09 PM
bsowa's Avatar
bsowa
Default Re: Dumb Question.....Help Please (bsowa)
From what I can see here http://www.corvettefaq.com/redir.asp?site=183
I have been working on the right nut.....I just cant get it with the clearance and angle I have under the car.
Might have to look like a real dumb a#$ tomorrow and reinstall the alternator and take it to Midas and ask them to loosen it for me.....
Old Aug 14, 2002 | 11:27 PM
trw's Avatar
trw
The nut on the left is welded to the PS housing.
Why not try and loosen the other end of the hose, from the steering valve and pull the pump and hose out together.
Hope this helps.
Terry
Old Aug 14, 2002 | 11:31 PM
bsowa's Avatar
bsowa
Default Re: Dumb Question.....Help Please (trw)
Tried that too.....I'm no Mr. Universe....at the same time I am no weakling , but I have had no luck loosening either nut.....
Old Aug 14, 2002 | 11:48 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
The big nut you are referring to is the flow control valve and it is tapped into the pump. Sounds like you are working on the correct nut (the smaller one). Again, if you are replacing the line try cutting the line off, then use a 6 point socket or a box end wrench. If it's rounded off, probably time to replace it anyway, probably a small pipe wrench and cheater bar will work.
Old Aug 14, 2002 | 11:51 PM
bsowa's Avatar
bsowa
Default Re: Dumb Question.....Help Please (Big Fish)
The line and nut are brand new....less that 2 months old. Hate to cut the line if I dont have to.....
What is a cheater bar????
Old Aug 14, 2002 | 11:54 PM
Zane's Avatar
Zane
You need to buy a good fitting wrench not a cheaply made one. I have Napa's fitting wrenches. All the hose nuts you MUST use a fitting wrench on them or will strip them. The one with the two nuts you need to hold the big nut with a standard 1" open-end wrench and the smaller one you must use the fitting wrench. A fitting wrench looks like a closed end wrench with a small opening to get over the metal line. I hope this helps out.
Old Aug 15, 2002 | 12:19 AM
bsowa's Avatar
bsowa
Default Re: Dumb Question.....Help Please (Zane)
You think I can get a fitng wrench at a NAPA store then? What do they run?
Old Aug 15, 2002 | 12:28 AM
bsowa's Avatar
bsowa
Would a flare nut wrench work as well?
Old Aug 15, 2002 | 12:30 AM
NHvette's Avatar
NHvette
Fitting wrench - flare wrench - flare nut wrench.
I'd get 'em at Sears Craftsman. 22.99 for a set:
http://www.sears.com/sr/product/summ...id=00944195000
:seeya
Old Aug 15, 2002 | 12:37 AM
Zane's Avatar
Zane
Default Re: Dumb Question.....Help Please (Daves_rusty_75)
http://buy.snapon.com/catalog/pro_de...re&dir=catalog
This one cost a bit more. The sears one should work fine. Yes flare nut wrench is the same thing.
Old Aug 15, 2002 | 12:44 AM
bsowa's Avatar
bsowa
Awesome....I saw the ones at sears and planned on picking them up tomorrow....what's up with snap-on....$145!!!!!! Jesus....and my wife was complaining about the $9 wrenches I bought at Bubba world!
Old Aug 15, 2002 | 12:58 AM
Zane's Avatar
Zane
The Snap-on comes with sentimental value built into the wrench. When you loose one you will :cry
Old Aug 15, 2002 | 01:57 AM
03 Z06's Avatar
03 Z06
That's for sure. They had a booth at Hot August NIghts last week. I knew their tools were pricey but just about fell over when I looked at the price of their "Special Edition Hot August Nights" rolling toolbox. Nearly $7,000, AND, it was purple, AND it was empty! No tools included.
Old Aug 15, 2002 | 03:32 AM
Double Aught's Avatar
Double Aught
I know it is to late, but why are you having such a tough time with this? My pump had two lines coming out the back. One had a simple pressure clamp on it and the other, the power line, had one nut. I loosened the nut from the top and it popped off. That was it, no biggie. I covered the power line with a plastic baggy and went about my bitness. Hope you get this fixed.
Old Aug 15, 2002 | 10:53 AM
bsowa's Avatar
bsowa
Default Re: Dumb Question.....Help Please (sd pacecar)
I dont know why I am having such a hard time.....All I know is that the bottom nut refuses to loosen....
To Dumb Question.....Help Please (Again)
