C3 Compressor runs all the time
Old May 10, 2015 | 04:38 PM
Burky454's Avatar
Burky454
6th Gear
Default C3 Compressor runs all the time
My compressor runs constantly if the control is in the off position or any of the a/c positions. If I place it on heat it will turn off the power to the compressor. Could it be the sending unit on the side of the heater box? This is where the wire comes from that goes to the compressor. If I unplug from the sending unit the compressor looses power, which makes since. Is that sending unit supposed to be closed all the time? I don't believe the compressor should be running when the control is in the off position. Any help, please.
Old May 10, 2015 | 05:09 PM
zwede's Avatar
zwede
Year of the car would be helpful. The AC system changed drastically during the C3 run.
Your problem sounds like a fault in the control head (the part with the *****/wheels on the console).
Old May 10, 2015 | 05:21 PM
Burky454's Avatar
Burky454
6th Gear
It is a 1971 454 automatic
Old May 10, 2015 | 07:04 PM
ajrothm's Avatar
ajrothm
A factory early 70s system with the A6 compressor does not cycle off. It runs continuously, freon regulation thru the POA valve is what keeps the evaporator from freezing.
Old May 10, 2015 | 08:12 PM
zwede's Avatar
zwede
Ok, '71 makes it a TXV system that, as ajrothm states, runs continuously. It should turn off if you put the selector in "off" though. There are two micro switches on the side of the control head that regulate power to the AC clutch. The problem is probably in one of those switches. From what I remember one of the switches is specifically for turning off everything when in 'off' (including the blower motor).
The AC should also be off when set to 'vent', and come on in 'bi-level'. If it comes on at the wrong setting, there are adjustments you can make to the switches.
Old May 10, 2015 | 10:24 PM
ajrothm's Avatar
ajrothm
Yeah the compressor should only run when the fan switch is on the first click from the left, thumb wheel in Max, Norm, Bi Level and I think defrost. On HTR or VENT the compressor should be off.
Either your fan switch is shorted, relay is hung up or power to the compressor is staying hot for some other reason.
Shouldn't take much trouble shooting to figure it out.
Old May 11, 2015 | 08:27 AM
Burky454's Avatar
Burky454
6th Gear
Good information, thanks. I will look asset the switches.
Old May 11, 2015 | 09:04 PM
Burky454's Avatar
Burky454
6th Gear
I had a loose micro switch on the control. After adjusting and tightening everything works just like it should. Thanks so much. You guys save people like me a lot of heart ache.
Old May 11, 2015 | 09:38 PM
zwede's Avatar
zwede
To C3 Compressor runs all the time
