A/C bracket
Old May 11, 2015 | 09:52 AM
jnywadd's Avatar
jnywadd
Default A/C bracket
Is there a way that you can mount the a/c compressor without having to use the top cross brace, or a bracket that you could use in which you do not have to use one? I have the original c4 compressor on a 1981 and do not have anyway to connect the top brace to a new intake being used, besides the ones without it look cleaner and neater anyway. Has anyone ever done this?
Old May 11, 2015 | 09:59 AM
hugie82's Avatar
hugie82
Try it without the cross brace and see if you have excessive vibration with the AC compressor on. I can't say I've done it on a late model c3 but I have done it on other cars. If vibrations are excessive you'll need to bolt in a modified bracket.
