1969 427/390 Throttle Return Spring
Hey guys,
Anyone know what the factory configuration for throttle return springs was on a '69 427/390hp? Did it have 1 or 2 springs (primary and secondary), what were the spring colors for the Quadrajet, and where did the spring(s) connect?
Thanks,
Sum
Thanks,
Sum
In 1969 there was only one spring.
https://willcoxcorvette.com/corvette...jet-68-69.html
see this diagram for hookup
https://chicagocorvette.net/diagram_...d=2347&rc=1945
I know this is an old thread but it just helped me out.
Follow up to the above, while a single spring is correct, does it make sense to run a dual spring set up?
There must have been something as GM wouldn't have installed an extra spring unless there was a reason but I have no idea why. I just use the old stock original spring and it seems to have lasted without a problem.
best of my knowledge it was a safety issue started around 1971
