starter question
Old May 12, 2015 | 07:49 AM
koolbz's Avatar
koolbz
Cruising
Default starter question
Hi everyone. Have a starter question. I put a new summit brand mini starter on this weekend and the starter stays engaged for 2-3 seconds after the engine starts. I re-shimed it and it still does it. Do you think it is the new starter or could it be the ignition switch. Thanks
Old May 12, 2015 | 09:49 AM
Ironcross's Avatar
Ironcross
Nope, not the switch..Its that high dollar substitute starter....Put the OE starter back on and get your money back...
Old May 12, 2015 | 02:41 PM
hugie82's Avatar
hugie82
With the battery disconnected, check the starters engagement. Check if the gear is sliding smoothly onto the flywheel or is it a really tight fit. If it's a tight fit, it will hold the starter in the engaged position after you let the key off. It may get better over time but keep that battery terminal wrench handy incase it sticks on.
Old May 12, 2015 | 09:41 PM
koolbz's Avatar
koolbz
Cruising
Thanks, best advice I have gotten. I'll check it out after work tomorrow.
To starter question
