1975 Engine BLING
Old May 12, 2015 | 07:33 PM
Jrstoke75vette's Avatar
Jrstoke75vette
6th Gear
Default 1975 Engine BLING
I have a 1975 coupe with the 169hp motor in it. As I cannot afford much in the way of a complete rebuild/crate, I thought I would clean up the engine compartment. I am looking at replacing with chrome the following:
Valve covers, Alternator, Starter, plugs, wires, Air Filter, timing cover to start with. Are these parts a simple swap out or do I need additional help in "dialing in" these components?
Thoughts on this?
Thanks for any feedback.
Old May 12, 2015 | 10:33 PM
76CSRvette's Avatar
76CSRvette
all those thing can can add up pretty quick. The pulleys and brackets can be changed to chrome also a can of krylon can clean up your engine pretty quick
Old May 13, 2015 | 09:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Jrstoke75vette
...Thoughts on this?...
It's your car and your money, but why not tune it then drive the car for a while before deciding what you want to do with it?
Old May 13, 2015 | 11:38 AM
REELAV8R's Avatar
REELAV8R
I wouldn't bother with timing cover or starter for bling. You can barely see those items.
Ebay is a good source for cheap bling items. Just make sure you know what fits your engine. 75 Chevy 350, should be plenty of choices.
Cleaning up the intake manifold and repaint and the brake booster can help with a cleaner look. Also radiator hose and thermostat housing.
Old May 13, 2015 | 02:15 PM
TedH's Avatar
TedH
When I rebuilt the top end of my engine, I used a grinder on the water pump and thermostat housing and sprayed both with a silver hi-temp paint. That brought a lot of clean/color to the top end. I sanded and re-painted the OEM air cleaner with a low-gloss black krylon. Chrome valve covers and black hold downs added contrast. Paint your intake to match the OEM color, nice color-matched distributor cap and 8mm Taylor Spiro Pro wires will really finish it off. If the alternator is dirty, try cleaning with a grinder but since it is aluminum, avoid ammonia. Simple green may help with grease stains. A/C compressor, sand/paint low-gloss black. Will really clean up the underhood area.
Old May 13, 2015 | 03:54 PM
Alan 71's Avatar
Alan 71
Hi J,
If you decide to buy some chromed pieces be careful where they're coming from.
China does some pretty bad plating…. that's why some of the pieces seem relatively inexpensive.
Regards,
Alan
Old May 14, 2015 | 03:58 PM
Haggisbash's Avatar
Haggisbash
The timing cover replacement requires the removal of the harmonic balancer, you need a special puller to do this. You can hardly see it so I wouldn't bother unless I was changing the camshaft. Plug wires are easy if you do one at a time so you don't mix them up.
Old May 14, 2015 | 10:03 PM
Jrstoke75vette
6th Gear
I am going to go with your suggestion. Kinda looking for some winter /fall projects
Old May 14, 2015 | 10:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
If I had to do it all over Id spend more on making power and nothing on bling in fact go to great lengths to make it look stock as possible, smog pump and all.
Leave em wondering...
Old May 16, 2015 | 10:20 AM
Easy Mike's Avatar
Easy Mike
Drive it all summer. By fall, your To Do List might be different from what it is now.
To 1975 Engine BLING
