'68 Throttle Cable
Old May 12, 2015 | 08:34 PM
ctuinstra's Avatar
ctuinstra
Default '68 Throttle Cable
What are you guys doing to make the '68 throttle cable work with a Holly? I found out the hard way tonight mine was bubba'ed. The cable was glued to the grommet; when the engine got warm enough, the glue let go and I had no throttle to get home. I had to wedge a screw I found inside the glove box into the grommet to hold it long enough to get home on a very light foot. I'd like to do it up right and never have to worry about it again.
Old May 12, 2015 | 08:53 PM
ctuinstra's Avatar
ctuinstra
Will this fit the OEM '68 cable that has the tube over it. This is for the Morse cables.
Old May 13, 2015 | 06:46 PM
blue427's Avatar
blue427
you need the brkt for an lt-1 which came with a holley.G.M.stopped making them along time ago but vendors like Paragon (maybe Wilcox?) have them in reproduction.
Old May 13, 2015 | 07:05 PM
John 65's Avatar
John 65
Just put one on last week. It wasn't getting all WOT
but the correct bracket fixed that.
Here ya go. You will need the little bolt and the clamp also.
http://www.ebay.com/itm/68-69-70-71-72-GM-CORVETTE-ACCELERATOR-CARB-BRACKET-HOLLEY-/110453518565?hash=item19b78af0e5&vxp=mtr
Old May 13, 2015 | 08:42 PM
ctuinstra's Avatar
ctuinstra
68 69 70 71 72 GM Corvette Accelerator Carb Bracket Holley | eBay
John,
It doesn't show in the photo, but does it come with the clamp and bolt (8 and 9)?
Old May 13, 2015 | 08:43 PM
ctuinstra's Avatar
ctuinstra
I wish I could use something like this. I bet a guy could drill out the hole larger if needed. I just wish I could find the size of the hole before purchase.
Old May 13, 2015 | 08:47 PM
John 65's Avatar
John 65
I ordered my bracket from that seller and no..... the bolt and clamp were not included with it.
http://www.ebay.com/itm/Corvette-Accelerator-Cable-Bracket-Clamp-Bolt-1968-1973-/171337342884?fits=Model%3ACorvette&hash=item27e4805fa4&vxp=mtr
To '68 Throttle Cable
