1981 voltage gauge/battery light issue
Old May 17, 2015 | 09:18 PM
EWJ's Avatar
EWJ
Default 1981 voltage gauge/battery light issue
Been working on an 1981-the charging system at the battery, the alternator and the junction block in the battery box is showing 14.67 volts. The exciter wire on the alternator is showing 7.58. With this, the volt gauge reads low and the battery light-along with the choke light - are on. I've checked all the gauge connections and everything else I can think of. Any ideas as to why this is happening? Thanks in advance.
Old May 18, 2015 | 12:28 AM
TimAT's Avatar
TimAT
Check the Choke heater fuse and the choke heater relay. For some reason GM tied the alternator exciter and the choke heat together. Maybe so the Choke light would come on if there was a problem with the alternator? No idea. Anyway, it's a place to look.
Old May 18, 2015 | 10:32 PM
EWJ's Avatar
EWJ
The 20 amp choke fuse is good. At the relay, there is power at one of the 3 pins: shouldn't there be power at 2 of the 3? When I put a load on the electrical system, like opening a window, the choke relay buzzes.
To 1981 voltage gauge/battery light issue
