[C3 1968] Alternator Regulator troubleshooting help !
Since january I am the lucky owner of a quite nice 1968 327ci coupe Corvette.
As I just finished a quite long trip with it late april (about 1000 miles in 4 days), I noticed that the battery charge failed
I tried to trouble shoot it but I am quite lost. The alternator seems to act as a dynamo as it doesn't regulate the power.
The regulator installed on the car by former owner isn't a Delco stock one and I can't figure out how it is wired.
Here are the tests I made so far :
- Hooking off everything on the alternator, it outputs ~16.3V when motor is running
- About the regulator, on the picture, all the wires are black because it has been painted
but on the front are wired +12V BAT :- a wire to the battery positive
- a wire to the alternator positive but it seems to have some resistance around 150 ohms
- 2 other wires that leads I don't know where. Seems that it is a way to gain +12V BAT ...
- None of the 3 other wires is hooked to the +12V ACC as I donc gain 12V on it with the key in accessory position. They aren't ground wires either ...
If I disconnect all the wires of the regulator, the amp gauge falls to -20A whereas it is at 0 when connected. Note that if I use the power windows motor running, il goes by -5A. So it seems to work.
Does anyone recognize the type of regulator ? What other tests should I do to troubleshoot ?
I join 2 pictures of my setup.
If I am correct, on the regulator, I shoud find :
- one wire to +12V BATT (I found it)
- one wire to power switch (+12V ACC)
- one wire to voltage output of the alternator
That should be all as the alternator is connected on a "one wire" mode ...
If anyone can help to understand what is done on my corvette, that would be great !
Thank-you and excuse my poor english as I am French
Also there should be a 2 wire connector attached to the 2 terminals on the right center of the alternator. The 2 wire connector senses voltage and activates the field to have the alternator charge the battery.
Do you have a wiring diagram for your 68? It would help you figure out what's there or missing.
I posted about this on 2 french forum 4 days ago and still nobody pointed out that this wasn't the regulator but the horn relay !
For now, I do own the Assembly Instruction Manual and the Repair and Tune-up guide for the 1968 Corvette. I am looking for a digital copy of the color wiring as it costs as much to send to France than the product price itself ... The thing is that neither classiccarwiring nor DocRebuild sell digital copies of wiring diagrams. So I am stuck with those in black and white in my digital version of the AIM ...
I will try to check out at the real regulator this week and post a picture of it to this post in order to be sure that this time I do check the right component !!!
Thank-you again for your answers :-)
How can I be sure that this alternator is regulated (from the pictures, it should be a Delco 12SI) ?
Also, doing my research, I saw a site where it is stated that I should remove the internal 40 ohms resistor when building a self exiting alternator. Is it mandatory ?
Here is the source of this info ...
