Alignment specs.
Old May 19, 2015 | 10:45 AM
bluedawg's Avatar
bluedawg
Default Alignment specs.
I am going to have my 76 aligned for the second time, the first being last spring when I changed the rear strut rods, bent tie rod end and new tires, got it back and was worse than when I took it in, the mechanic at the alignment shop said the shims in the rear were rotten and that I needed new shims and to bring it back I've got new shims and just want to ensure that it's aligned properly, so could some one post the alignment specs for my 76? Thank you.
Old May 19, 2015 | 10:48 AM
zwede's Avatar
zwede
You need to specify which specs you are looking for. The shop will have the factory specs. Are you wanting more aggressive settings?
Old May 19, 2015 | 02:14 PM
Kid Vette's Avatar
Kid Vette
Take your pic.
Guldstrand
Vette Brakes & Products
Hopefully, they're both supporting vendors.
Old May 19, 2015 | 02:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by bluedawg
...could some one post the alignment specs for my 76?...
They might be in your owner's manual.
Old May 19, 2015 | 04:01 PM
Kevin BC's Avatar
Kevin BC
These may be useful, but note that they specifically say these are not the stock specs.
File Type: pdf
Old May 19, 2015 | 11:43 PM
bluedawg's Avatar
bluedawg
Thanks fella's.
Old May 20, 2015 | 06:24 AM
midigike's Avatar
midigike
Thanks fella's.
I needed this info too. I'm having my alignment done next week. Sweet, thanks for posting info.
Old May 20, 2015 | 09:42 PM
'75's Avatar
'75
If your rear trailing arms haven't been out in the last few years, it's likely the pivot bolt where the shims are is rusted in. The alignment shop wont be able to adjust the rear tow because the trailing arm won't slide on the bolt to get the new shims in the right place.
Old May 20, 2015 | 11:40 PM
bluedawg's Avatar
bluedawg
Man I hope not, if it comes to cutting the bolts and all, I might as well change the trailing arms for rebuilt trailing arms. It would be my luck. I'll pray to zora duntov and we'll see what happens. Thanks for the heads up and potentially crappy news....
To Alignment specs.
